IAT too high, need help :(
I believe that sensor 1# is what is feeding the reading in the hidden temp menu on the dash. That is where I saw the jump in idle/standing temps when I switched to the Dinan intake
I don't think so. What was it reading at WOT? if it went up a ton, then no.
Crypto79
Washington DC
2023 Supra A91 MT, 1997 sc300 5 Speed
while idling a half Dozen or so degrees (C) over ambient. On WOT (while moving) it goes down to near-ish ambient. Slightly larger spread when having been on it and engine bay is hot
My observations was that the stock intake does a better job at pulling air from in front of the radiators while stationary, the Dinan pulls from behind. The spread between driving and stationary was notably different via the hidden temp gauge after the intake was installed.
Moves in real time-ish
Okay if it drops to near ambient at WOT then it's most likely the sensor right after the intake filter and pre-turbo.
The OEM intake pulls from behind the right side headlight.
Crypto79
Washington DC
Yah the OEM airbox seals to the duct where the Dinan duct sit in front of it open to the bay.
kern417
Kevin
Cincinnati
2018 440i
Just a thought - if anybody parks their car, you'll see the same thing. the coolant cooks when the car is parked with no airflow, so IATs will be high. Once you start driving, temps should go down.
If you are getting limp mode/drivetrain malfunction, post a scan of your code reader. It will show what the problem is.
Did the bleeding check. Did not see any bubble in my radiator tank and is at the max coolant level.
Do you have an independent BMW mechanic you trust? Worth their weight in gold if it becomes too hard to solve.
a90fresh
instagram.com
Toyota Supra A90 3.0 Premium
RIP? IAT ?
My IAT went up after turbo upgrade, since there are no turbo blankets for Omega 65, just had mi wrapped (laser welded) by Headershield.
Well post improvements after install.
kern417
Kevin
Cincinnati
2018 440i
RIP? IAT ?
I would expect engine bay temps to drop but unfortunately that won't provide a significant improvement in IATs.
This. Unless he is running an open cone filter sitting on the manifold.
a90fresh
instagram.com
def running open intake/filter, I know it’s higher IAT’s, but sorry just love the sounds ? of running open especially with a T51R Mod setup.
