MOA90
I second thisJustin at Twisted Tuning is great, I highly recommend him. He has very good customer service!
If you want reflex integration then MHD would be your choice.Quick question I went with BM3 so I know the features etc etc, but why would I go with MHD if I have all the features mentioned even when my ecu is post 6/2020. Isn't MHD lagging behind BM3??
I'm confused is the MHD+ for pre 06/2020 ecu's or post 06/2020?If you want reflex integration then MHD would be your choice.
currently for pre june, but itās coming to post june also.I'm confused is the MHD+ for pre 06/2020 ecu's or post 06/2020?
for pre june EcuTek is the way to go. However, if reflex integration will come to post june Ecu's that will be big.currently for pre june, but itās coming to post june also.
it doesnāt really make a difference between Ecutek and MHD now. Whatever your tuner uses should be the choice.for pre june EcuTek is the way to go. However, if reflex integration will come to post june Ecu's that will be big.
The TCU is separate from the DME so you can flash XHP without having to unlock your DME with Femto.Hello and for the TCU patch itās running on dme femto unlock or just before 06/20 ? And the braap when you shift up (for european version)
Yes i know but in the 4.50 of mhd i have see the TCU patch and if itās running on my femto unlock i donāt need xHPThe TCU is separate from the DME so you can flash XHP without having to unlock your DME with Femto.
just because on MHD is shows the TCU patch you donāt have XHP. You still need to get the XHP license and flash it.Yes i know but in the 4.50 of mhd i have see the TCU patch and if itās running on my femto unlock i donāt need xHP
sorry for my english
Let me know if you have anymore questionsThank you. You just made it harder for me to choose between MHD or BM3. My 2023 MKV 6MT is stock, but looking at unlocking soon with Femto and need to decide which direction to go.
they are correct. MHD+ port injection integration is barnone.Same, my shop is now telling me go MHD+ as the PI integration w/ Reflex is much better, among other things but yeah, his opinion but i'm not going to argue as they do this every day.
Thank you very much.I second this
honestly speaking MHD+ has a good amount of things under the hood that BM3 and even ecutek dont have aside from much better port injection control than BM3Quick question I went with BM3 so I know the features etc etc, but why would I go with MHD if I have all the features mentioned even when my ecu is post 6/2020. Isn't MHD lagging behind BM3??
there are in fact some things under the hood that MHD+ has that no other platform has.it doesnāt really make a difference between Ecutek and MHD now. Whatever your tuner uses should be the choice.
If you have xhp you don't need the patch used. If you don't have xhp, enable the patch. But still should get xhp at some pointYes i know but in the 4.50 of mhd i have see the TCU patch and if itās running on my femto unlock i donāt need xHP
What do you recommend for Flexfuel kit if I'm gonna go MHD?Let me know if you have anymore questions
The MHD one, mine (out of stock currently), or any that use Zeitronix module. However, does your car have a reflex plus? Because that can be used instead of the prior mentionedWhat do you recommend for Flexfuel kit if I'm gonna go MHD?
No Reflex yet. I'm bone stone aside from a downpipe and exhaust. You don't recommend the Visconti flex fuel kit?The MHD one, mine (out of stock currently), or any that use Zeitronix module. However, does your car have a reflex plus? Because that can be used instead of the prior mentioned
