iceman600
- Joined
- Apr 1, 2022
- Threads
- 4
- Messages
- 28
- Reaction score
- 8
- Location
- California
- Car(s)
- 4runner Type R Supra MKV
- Thread starter
- #1
I got 2020 3.0 stock and my CE lit up. I scanned it and this is what I got. Does anyone have the same code that can give me advice on what I'm dealing with here?
- DME active codes -
135A08 - Valvetronic servomotor position sensors, signal: Not plausible.
190302 - Diagnostic module for tank leaks (NVLD), fuel tank ventilation system, micro-leak greater than 0.5 mm detected.
21B055 - Upper radiator shutter: Internal communication fault.
21B056 - Lower radiator shutter: Internal communication fault.
CD990B - Message (request, rear axle speed, 69.3.4) missing, receiver DME, transmitter DSC.
CD990E - Message (front axle speed request, 69.3.4) missing, receiver DME, transmitter DSC.
- DME shadow (inactive) codes -
11B401 - High pressure fuel: Pressure too low at or after engine start.
11B501 - High pressure fuel: Pressure too low after engine start.
135501 - Valvetronic: Output stage overloaded (warning threshold value for overload protection exceeded).
1A400B - Electric fan, function: Switched off.
21A026 - Combustion engine: Abnormal ignition key or automatic engine start-stop function start detected.
24000B - EWS-DME interface Timeout.
