PCV Valve Replacement
andrewtrxnn
Andrew
Irvine California
2020 GR Toyota Supra 3.0
Trying to locate the PCV valve, Ive been looking at B58 Engines. There is usually an area next to the Oil cap where the PCV valve is located, unfortunately all videos are on 340i and none on the Supra. Ive been looking on forums trying to find the location and easily way to open the PCV to see if theres any tears/rip on the rubber. If anyone could give me any insight on this situation.
My apologies if none of this makes sense. Im a bit confused myself.
Benjilis
Ben
St. Louis
Supra MKV, VW CC R-Line
It’s mentioned in CAI with inlet install videos and maybe on charge pipe install videos.
it connects to the inlet, front of the car. Trace the line to the other end
andrewtrxnn
andrewtrxnn
Andrew
Irvine California
Thank you! Figured it out
Tiko
Tiko
2020 Supra Launch Edition
Where did you buy it? Can you give me the part number?
kaj
Fresno, CA
'00 360 / '69 Charger
Why are you guys already replacing PCV valves???
Tiko
Tiko
my car is significantly smoking, spoke with my tuner, he said it could be the PCV. My oil is good been checking everyday, temps are good and logs are good.
