potater1
- Thread starter
- #1
I recently drained both the high-temperature and low-temperature coolant circuits on my 2020 GR Supra, so both systems are currently completely empty.
I have the workshop manual and understand that there are two separate bleeding procedures:
My main question is: When both circuits are completely empty, does the order of bleeding matter? Should I bleed the low-temperature circuit first and then the high-temperature circuit, and does one procedure help fill/bleed the other circuit at all?
I also have a question regarding the coolant reservoir caps during the filling and bleeding process. I understand the official procedures specify the cap being closed for the bonnet closed procedure, but it seems like you want it off for the other bleed procedure.
So hypothetically, if the low temp procedure does also bleed the high temp. Should I keep both caps off to see if I need to top off both reservoirs while running?
Since both circuits are completely empty, I want to avoid running either pump dry/mostly air.
Thanks!
- Low-temperature circuit: ignition on, engine not running, bonnet open.
- High-temperature/engine circuit: bonnet closed, engine starts and runs the automated bleeding procedure.
Thanks!
