Question on front sway install
Natek
Nate
2020 launch
can a front sway be installed with the car planted on all wheels or does the car need to be jacked up? I have a four post lift and can easily get to everything with the car planted but i am not sure if tension needs to be relaxed to do this.
Illsic_Design
Josh
Nor-Cal
When you tighten everything up you should have the front suspension at ride height(how the car sits normally) and not unsprung
