suvneer wing hardware specs
Han_Supra
Denver, CO
2023 Toyota Supra 2.0 Stratosphere Blue
Anyone know the hardware specs they bought for longer bolts and larger washers for their suvneer wing? I hear the stock ones should be replaced but can't find the exact size to purchase. Looking to save myself a trip to the hardware store.
Cheers
Vegas17
Scott
2021 Supra AT
It's a mix of m5 and M6. I bought a kit from amazon with M5 x 8, 12, 16 and 20mm and M6 with same just to cover myself. This video had just m6 linked but I'm pretty sure it was a mixture with m5 as well for the one i got.
Han_Supra
Denver, CO
I plan on buying titanium bolts online for the higher quality and rust proof properties. Unfortunately the titanium hardware doesn't seem to be sold in variety kits that have multiple lengths. Which is why I was wondering the specific lengths. Sounds like 20mm would be the way to go but I'll verify at the store and post exact specs and amount required for others ?
Just buy Grade5 Ti bolts in the sizes you need off ebay from China.
Han_Supra
Denver, CO
6x M6 bolts @35mm length
6x M6 washers @ 16mm outer diam
4x M5 bolts @40mm length
4x M5 washers @12mm outer diam
All stainless steel.
The washers outer diam are larger than stock, but could go for a bit larger.
RTV Silicone applied around all bolt holes for waterproofing
Foam strip applied along outline of wing stand where it presses against the trunk. I just used the supplied foam stripping it came with.
3M tape (and silicone) to stick the end plates on the stands, as I had the paint shop cover the bolt holes to not have exposed hardware showing.
