Took the door off to wrap the door jams installed and the passenger side door lock wont lock or unlock with keyfob or button inside the car
Josh
Fort Lauderdale, fl
2020 Toyota supra
Hello everyone,
I took the door off of my 2020 Supra to get the inside door jams wrapped. When installing the door and plugging back in the connector the door passenger side door lock does not work. The key fob button doesn't work for that's side either does the door lock buttons. The handled when pulling the door lights up. When locking, the mirrors close and the alarm sets. I am very confused what it could be. I can unlock the door by opening the handle and locking it by pushing the lock manualy down. If I dont lock the car manually and open the door with the alarm set the alarm will go off.
Any suggestions on what it could be I would greatly appreciate it.
Joebednar4
Joe
Richmond, VA
Haaahahahahaa I did too!! Lmao, you have to disconnect the battery, and leave it for a couple hours (probably less) and your lock assembly will reset. Clearing it in the computer first is probably a good idea, but doesn't work alone.
Vertex
Vertex
Midwest
2022 3.0 Supra
Instead of just leaving it unplugged for a couple hours you could also try to touch both the battery cable ends together while the battery is not hooked up. I know this works on another vehicle manufacturer to reset codes and other stuff as well. I'd give this a shot first
