What turbo intake are you using with your aftermarket turbo? (Stock location turbo)
Evilpenguinking
Jack
Indiana
2021 Toyota Supra
Anyway to retrofit poplar brand turbo intakes like hks, eventuri, etc onto pure, daw, remnant?
The Pure solutions that use the OEM turbo housing will fit aftermarket intakes. But all of the larger mid-frame turbos won't fit well, or at all, because the turbo inlet is like 2x the size of stock.
But with some clever cutting and silicone couplers, you could probably jank this together. Couplers come in every shape/angle/size, including reducing or enlarging adapters.
That said: you should fundamentally expect that an aftermarket turbo likely doesn't use a stock-sized intake. Any workaround is on you to DIY and there's no clear path for it.
