Any keyless entry systems compatible with oem key?
Witchhunter467
Alex
Olympia wa
1983 Toyota Supra, 2001 Subaru Impreza
Hey, I have an 83 supra I picked up recently, which I wanna jank together keyless entry and maybe remote start for, I would like to use a gr supra keyfob if possible, for the funny, but idk if there are any systems compatible with it, if anyone knows of one or knows someone that might be able to figure it out, lmk, thanks
BMWAF
In orbit
A90 Supra; FN2 CTR
Good luck getting a Mk5 key. Good luck decrypting BMWs coding.
This. Not only are you fighting the chasm of time; you're also fighting brand compatibility; modern security; and as many on here can attest, complete (un)availability of keys.
iambak
Bak
Supra
This type of entry system would likely need to be custom-built rather than purchased ready-made. Here's what you might consider:
You could potentially build a system using:
- An Arduino microcontroller
- A BMW easy entry receiver module
- A compatible BMW key fob
The challenge would be writing the code to make the Arduino communicate with the BMW module and then integrate that with either your existing central locking system or an aftermarket one.
While this is technically possible, I should note that I haven't attempted this project myself. Given the complexity and time investment required, you'll need to weigh whether the end result justifies the effort.
I hope this gives you a better sense of what might be involved. Good luck with your project!
