svinorenko
- Thread starter
- #1
<2000 km 2024 MT, already happened like 3-4 times, during spirited driving sessions I notice clutch pedal not fully releasing back. Even after drifting when I don't even touch the clutch at all, sometimes the pedal becomes soft afterwards and not going fully back. Then it magically heals itself after like 30 seconds.
But yesterday it became worse: I was driving normally, then wanted to do a launch start, from 4000 RPM I dropped the clutch and launched off, but the car is stuck in 1st gear, clutch pedal did not came back (only halfway), and I couldn't shift gears. This happened immediately after first hard launch during regular city cruising. Even more suspicious was that fully depressing the clutch did not do anything - car was still rolling forward as like the clutch is engaged. After I manually pulled the pedal back to me, everything became normal again. What was that? CDV is not yet removed, but there were no clutch burning smell, and it physically can't be since it happened literally after first clutch dump. The car is stock (at least powertrain related, only put coilovers)
