Clutch Squealing in 1st gear
Echo29
Jericho
Toronto Canada
2023 GR Supra
I change the clutch on my 23 supra with a lightweight flywheel and there has been this squealing noise ever since. Is that normal with a lightweight flywheel?
Thanks
Thanks
No not normal.
tracer bullet
Greg
MN
2025 BMW Z4 M40 6spd
Sustained squealing? Pilot bearing?
Did you do the clutch or a shop? How experienced are they with clutches? When exactly does it happen, i.e. with the clutch pedal pushed in, only when it's out (not pushed in), while you are driving?
Hasan
Hasan
United Arab Emirates
Too many to list
Thanks
Does it squeal when clutch pedal is pressed in or when the clutch pedal is released? Did you change the throw out bearing? Sounds like a TOB issue.
