DAW 6769 help with setup
MPJR03
Mario
CALIFORNIA
2023 Toyota GR SUPRA 3.0
This is my current setup, it’s still in the shop being put together. I’m aiming to keep things conservative with this build—what would you recommend I focus on? Trying to keep a OEM look.
H&R lowering springs
13mm spacers in front, & 15mm spacers in the back
MHD Tune & FEMTO UNLOCK
XHP Transmission Tune
VRSF Catless Down Pipe
FTP Charge Pipe
MST V2 Intake
Borla Exhaust
MHD Flex Fuel Kit
CSF - B58 4-Piece Competition-Spec Cooling Package, MKV A90 Supra
Radium - Dual Catch Can Kit | MK5 Toyota Supra A90 B58
Dorch B58 Gen2 Stage 2.5 DS25 HPFP Upgrade
BN B58 Intake/Turbo HeatShield
S58 OEM Injectors
Wagner Tuning Toyota Supra MK5 A90/A91 B58.2T EVO1 Intake Manifold w/ Integrated Intercooler
DYNAMIC AUTOWERX BMW/SUPRA B58TU GEN 2 (NEW GEN) 6769 (6 PORT)
TMS A9X Toyota Supra Plug-and-Play Low-Pressure Fuel Pump
Ramair - PRORAM Medium Cone Air Filter with 102mm OD Neck Velocity Stack
You don't need the LPFP, you will max out your transmission before the LPFP.
If the CSF cooling package isn't installed yet, sell it. It's worse than OEM
2021Supra
Alabama
2021 Supra, 2021 Lexus RC300, 2007 Tundra, 1975 Ch
Did you finish the car? Results?
MPJR03
Mario
CALIFORNIA
Everything is fine except the turbo! I’m trying to fine an oil feed regulator to lessen the pressure of oil that’s being sent to the turbo. I got the oil pressure restrictor but it wasn’t enough to slow it down the pressure was still to high.
2021Supra
Alabama
I used the Turbosmart inline oil restrictor. It doesn’t go above 40-45 psi, regardless of throttle response. I cut off the factory OEM oil feed line, placed a new fitting, and ran two -4 lines to the block and the TS oil restrictor. No issues. Cleared up my smoke almost immediately.
coldtires
SW
'21 Supra 3.0, '22 Mustang GT
Somewhat off-topic, and I do not intend to disparage DAW in anyway, since I know people shit on it here already 😆 - but is an oil restrictor required for any other bigger turbo for the 600-800 range? It seems like the only times I've seen an oil restrictor being needed are for DAW turbos smoking due to oil.
I myself also formerly had this issue, but I'm not sure if it was due to my faulty oil pump (replaced now) over pressurizing the turbo, poor crankcase ventilation (wasn't running a breather then), or the DAW UFX having poor drainage (what I think is the issue).
I know Trevor from DAW posted a video on Instagram on what could cause the smoke, but it seems like it can also be attributed to being a poor design of the turbo if the solution appears to be needing an oil restrictor.
i3igpete
Chicago
2023 3.0L 8AT
OilFeed restrictor generally depends on bearing type, not wheel diameter. Ball bearings need a restrictor or pressure regulator, journal bearings will generally gulp as much oil as you can feed it, since oil is intended to go over, around, and through the floating bushing.
coldtires
SW
Ok and unless I'm mistaken, aren't DAW turbos journal bearing?
