dongar tech USB splitter from rain sensor install
EvilMKV
Taylor
Seminole, FL
2021 Tundra TRD Pro, 2023 Supra 3.0 Premium
The ones suggested just push into the pin locations and are held in place by friction. I used them for my radar with no problems.
Like, just craming them into the back of the plug with the factory wiring?
swrdply400mrelay
i installed this and it works as intended but like OP said, it does have power all the time so i have to turn off the cam every time i turn off the car.
I did some more research and found out that dongar also offer some two-prong universal adapter, pretty similar to the mirror tap that is being used for radar detector. Links below.
https://dongar.tech/products/twoprong-miniusb
https://dongar.tech/products/twoprong-microusb
Im going to use these instead and tap into the other connector (below the pink/reddish one).
Sorry if I missed it, but what do you tap the black and red wires to?
spongklong28
RR
'21 GR Supra, '20 Subaru STI
i referenced it with the vid below.
CTTO:
basically black to the far left, and red to the far right. there is ample space for the prongs so you can just insert it in the pin locations. you can see how it was on the yt vid above at around 2:14
PureDrifter
2023 GR Supra 3.0 Premium MT, GX470, LS400, MR-S
Did anyone ever figure out if the rain sensor was constant power or if it turned off 7-8min after the car turns off like other "constant" power in the car?
NINaudio
George
Illinois
I'm wondering this too.
EvilMKV
Taylor
Seminole, FL
I'm curious as well. Looking at the harness on Dongar, it uses the same rain sensor plug, and the wires running from the adapter to the usb are the same power/ground wires people are tapping for radar detectors. I have a feeling this will power down after the 7 minutes, but the OP and others likely didnt wait that long and just assumed it stayed on. I'm going to give it a try.
PureDrifter
The team at Dongar sent me 2 adapters to try out and see if the power stops after the BCM shuts down. I'll report back in a week or two after I've had a chance to get to it.
EvilMKV
Taylor
Seminole, FL
Awesome. I'll wait to order anything till you report back.
EddieNel
Eddie
Central Louisiana
F350
We’ll get your ass to it. We waiting!lol I know my Uniden powers down after like 6 or 8 minutes using the cigarette plug in my truck.
EvilMKV
Taylor
Seminole, FL
Any news? lol I feel naked without a dashcam and want to order one soon
EvilMKV
Taylor
Seminole, FL
Klattu
Yorkshire
Current: Toyota Supra GR pro
What I want to know is how exactly he pulled that stupid red plug out? And without pulling the mirror off. Good grief.
I'd like to know that also...it won't budge, is there a tab you press to uplug it?
Awales74
Andrew
Dallas Texas
Supra, Mazda 6
I did something kind of lame. Once the rear view mirror is pulled off it will hang down and almost touch the screen. put a folded rag over the screen and you can set the mirror on the top of it. Then you push the wires into the plug while it's plugged in.
