dongar tech USB splitter from rain sensor install
EvilMKV
Taylor
Seminole, FL
2021 Tundra TRD Pro, 2023 Supra 3.0 Premium
The team at Dongar sent me 2 adapters to try out and see if the power stops after the BCM shuts down. I'll report back in a week or two after I've had a chance to get to it.
Dont leave us hanging man lol
EvilMKV
Taylor
Seminole, FL
PureDrifter
2023 GR Supra 3.0 Premium MT, GX470, LS400, MR-S
Results! (but not what you probably want to hear :( )
Dongar's Porsche Keyway 1 adapter works great, but doesn't turn off (acts like constant power). I timed it from when the car was locked, with the keys in and out of the car, cold dash, keys far away from the car, etc... but it's still powering the USB plug for more than 8-10 minutes each time.
I suspect there are minor but significant changes in the wiring or BCM on different years/trims, but can't confirm.
Dongar had sent me their Porsche Keyway 2 as well but it uses a mirrored connector that did not look like it would fit and I ran out of time to see if it would. May give it another shot in a couple weeks, will update if I do.
Testing was done on my 2023 3.0 Premium (MT).
EvilMKV
Taylor
Seminole, FL
Well that stinks. Thanks for testing it out. Wonder what the difference between the two is since it looks like they use the same harness plug.
PureDrifter
It does look like the rain sensor part number changes depending on if the car has a HUD or not, may possibly be a wiring difference?
OP that posted had a HUD too, judging from pictures.
gone for SIV for a few days, will investigate more when I get back.
PureDrifter
Final update for now:
Looks to be a wiring difference in the RLS for HUD/Non-HUD cars, but I can't confirm without access to BMW EWD from Ista. Either way, for HUD-equipped cars looks like the 3 lines going into the RLS are constant +12v, LIN (for CAN), and Ground, so no-go on using the RLS plug for powering a dashcam :(.
I'm probably going to use a universal 2 prong adapter to microusb setup with an adapter, or if I can, find a USB-C variant. Nobody seems to be making mirrortaps for the actual rear view mirror plug, sadly.
EvilMKV
Taylor
Seminole, FL
Thanks for the update. Seems like the prong taps folks use for radar detectors are the style to go with then.
Samsamsam
Maryland
2023 GR Supra
Hi There I know its been while but just ordered this adapter (3 pin keyway 1) and installed with Garmin 56 dash cam . Everything works fine so far but Idk if its constant power or no. I have parking mode enabled for garmin 56 but it doesn't show that when I left the vehicle. Any input?
EddieNel
Eddie
Central Louisiana
F350
Mine cuts off a few minutes after I lock the doors.
PureDrifter
what year/spec do you have and what adapter did you use?
It's been suspected it's the Premiums w/HUD that are constant power for the rain sensor.
2022 Subaru BRZ, 2024 Toyota GR Corolla
Anyone else running this Dongar adapter? Hopefully it’s not constantly on. Got an A90 Supra Premium
Turbro
Somewhere USA
Supra
im running it, 3 pin into the mirror adapter. Seems to be constant power. I have a MT 3.0 A90 base w/ tech pack. So no hud. I just unplug it for now until I figure out how to not have a battery draw.
I am a little concerned w the dongar usb adapter I have, has a small blue led in the usb section to show power which will draw power on long park. Which I do because I don’t drive in winter or daily.
