EcuTek my 1 Month review
65sohc
Ken
Posts
308
Fresno, CA
2020 Supra, 65 GTO restomod, 66 Mustang restomod
My Supra was tuned by Marin and I am in CA also. Nothing to worry about, the car feel like stock but stronger, and Marin will work with you to have the map working to your needs. As for torque and HP, I can only speak from the logs, but with E50 the peak was 750 Nm of torque and like ~430 kW (~570 hp) to the crank, here the logs:
https://datazap.me/u/000camus000/e50-v1-log-4-hard-pull-50-120-mph?log=0&data=2-8-9-34&zoom=116-421
With 91 Oct the peak was ~ 640 Nm and 365 kW:
https://datazap.me/u/000camus000/91-oct-v5-evening-runs-21°c?log=0&data=2-6-7-32&zoom=179-433
TLDR: The mods are AMS DP, Verus heatshield and at the time MST Intake, now I moved to Eventuri, but the performance is almost the same. I think it's more than enough power, for 91 Oct those 365 kW are ~489 hp to the crank, like 420 whp. For E50 430 kW ~576 hp to the crank, like 500 whp, maybe a bit more. And this is consistent with what people is seeing on the dyno.
Edit: Folsom? do you also work at Intel?
I find your Ecutek logs confusing. eg. your Boost Pressure Target is 2560 hpa which equals around 37 psi.
iceman21_23
iceman21_23
Posts
46
Houston
2020 Absolute Zero Supra
  • Thread starter
  • Thread Starter
  • #77
you need to subtract absolute pressure
Nathwraith
Nathan
Posts
31
UK
www.wraithauto.co.uk
2019 Supra, 2016 NSX, 2011 CRZ
Going back to the OP.
My car (Ecutek, catless downpipe pipe, 437whp) makes the same annoying low rpm, light load vibration/buzzing.
Messaged my tuner about it so we’ll see!
Advertisement
Advertisement
