Is it possible to adjust idle RPM w/o Femto and SW?
Strat-Supra
2024 MT Supra
Basically as the title states, I have a 2024 MT and I'd like/need to raise the RPM at idle to offset the resonance induced by swapping the engine and transmission mounts. I wasn't planning on adding a tune or anything as the car has plenty of power for the street, so I'd rather not go through the whole process and funds just to raise the RPMs at idle.
I suspect it's the only way but I'm hoping maybe someone knows a trick.
dustwhyn
Dustyn
2024 M240i xDrive
As others have said, not possible without an unlock and tune.
garudathree
ny
none
supposedly possible via protool/ista, but i haven't figured it out yet
garudathree
ny
none
That is a service function and not a permanent solution. When you exit the service function, the vehicle will revert to default settings.
is that new for g series vehicles? on f series ista specifically states "permanent adjustment (programming) and end test module" within this service function
dustwhyn
Dustyn
2024 M240i xDrive
I don’t think it’s new behavior. It’s never been a permanent adjustment. I’m not sure why it says that.
Strat-Supra
2024 MT Supra
That's crazy, you can't adjust the idle on your car anymore, that's a serviceable function. Allow adjustments within a bound range to ensure the car still meets regulations and legal what nots.
