KW V3 Compression and Rebound
jon201
Jonathan
Supra mk5
Hello, for those of you with KW V3s, what compression and rebound settings are you running, and how does the car feel? I just installed mine and I’m currently on the factory settings.
Hasan
Hasan
United Arab Emirates
Too many to list
Start at the mid point. If it is too stiff/soft reduce/increase compression. If it is too bouncy, increase rebound.
Ideally, you would want compression damping high enough so that it does not bottom out and rebound high enough so that it does not bounce twice.
