Port injection with LPFP results on with stock turbo
Mason
Mason
Kenosha WI
520whp/625wtq out of a stock turbo is not conservative at all.
[/QUOTE]
Assuming you run port injection or upgraded HPFP on both. The pure 850 is the better option for power.
Without extra fuel support. The more ethanol you run the less power you make dye to the stock HPFP running out of flow.
This was my setup 2 years ago. I ended up doing port first and then cts turbo closely behind. Pumps and all. Did it right
Got_M
Kyle
KCMO
2022 Supra 3.0 Premium
[/QUOTE]
Have a dyno graph to prove those results with stock turbo? Genuinely curious. I am running charge pipe meth and turbo is making around 24psi. Trims look healthy. That's about all it wants safely.
I should also note I am stock turbo full send jb4 with locked ECU.
Mason
Mason
Kenosha WI
@Got_M
[/QUOTE]
[/QUOTE]
I don’t have a dyno of stock turbo. Honestly the ported stock snail didn’t pull much harder than stock fueling, therefore I just went for the turbo right after.
But I was tuned by Payn at the time and had basically 0 timing. I have never used a jb4
Bebo19
Bebo
Austin, Tx
Toyota Camry
[/QUOTE]
what pumps did you go with?
Mason
Mason
Kenosha WI
I got the lpfp from Visconti. I would get it elsewhere in hindsight
_Sp1ral0ut
Jeff
SC
Anything wrong with it in particular or...?
Mason
Mason
Kenosha WI
Had a wire issue during install and needed another wire harness. Big V refused to sell me the required harness, but recommended I buy the entire lpfp kit
_Sp1ral0ut
Jeff
SC
Gotcha. Ouch. Sorry you had that happen.
