Remnant Omega 65 logs
Evilpenguinking
Jack
Indiana
2021 Toyota Supra
Bare with me, I’m a complete newb when it comes to logs and how I should do them. But I have a few short logs I’d like to share with you guys. If there’s anything better I can do to get some better logs please let me know. I don’t know how to read them so I’d like some insight on how the logs translate.
Car is a 21 with a base tune from Sameh on BM3. Remnant Omega 65 turbo kit, open down pipe on 93 octane. Tiny bit of extra ethanol from previous setup.
https://bootmod3.net/log?id=65fc4351ab4af232b5d09232
https://bootmod3.net/log?id=65fc418f23b2db3d9df24ed8
https://bootmod3.net/log?id=65fc4171173e641b53849bdf
What are you hoping to learn? A base map is going to be quite conservative, so not likely to highlight any real problems. At most, it'll show some figures that are sub-optimal until the tune is dialed in.
Evilpenguinking
Jack
Indiana
2021 Toyota Supra
Honestly just looking to see if I’m ready for a tune revision. Trying to see if everything is as it should be.
Bryan / Briana
Your moms bedsheets
You need to start your logging earlier, a lot of these are cut off. You also need to log in 4th gear at least. way too much wheel spin in these logs in 3rd.
Evilpenguinking
Jack
Indiana
2021 Toyota Supra
I was using the auto log feature. Guess I’ll use the other way. Thanks for the input!
Evilpenguinking
Jack
Indiana
2021 Toyota Supra
Bryan / Briana
Your moms bedsheets
_Sp1ral0ut
Jeff
SC
