solutions for oil temp on track
You aren't still going to run that tune on track, right? IAT aside, that tune is... absolute trash.
Unless that "tuner" takes 10 psi out of it, ran better timing, etc.
Edit, looks like the "tuner" did indeed take 10 psi out of it, and now really low boost up top, well.. at least it's safer now, still a really messy tune.
https://norcalmotorsports.org/logapp/share.html?t=d141b3ea17ac1f643c041b42
kyippee
Ken
2021 Supra 3.0, 2022 M235
@razorlab that is the same tune / maps being run as earlier- all that changed was the manifold air pocket being removed. Looking into some stuff.. and might have another tune to run
RE: the data thanks for taking a look! I should look at boost target too. I’m gonna check what map 1’s targeting too
It's def not the same, load and boost actual and targets are totally different. Boost curve is different, timing different etc. Maybe you switched maps?
Earlier log
Current log
kyippee
Ken
100% the same flash of same tune being run on the earlier and later logs done on Nov 25 like the linked ones! I'm guessing the targets/timing/curve vary by heat...
I'm wondering if the spikes in boost target and the fuel pressure shortfalls are the symptoms of an optimization to try and get the turbo to spool up faster in certain situations like heavy throttle input when the car is at low load, and that the tuner isn't actually trying to get the car to run 33 psi all the time, but in past track logs my car triggered that optimization for too much of the driving?
I vibe-analyzed this a bit.. https://ken-supra-log-lab.adorableblade3.chatgpt.site/boost
Strat-Supra
2024 MT Supra
I really don't want to be and try not to be that person but it's hard to watch the continuous back and forth when people ask for help and then basically ignore and/or argue the help they receive.. If two people tell you your tune is bad after looking at your logs then your tune is bad, especially when they pointed out exactly why and where the tune is bad using your own data.
Again, don't take this the wrong way, because I'm not trying to be rude or condescending, just asking you to listen and hear the help and advice people are providing. Granted you might be protective of your current tuner and that's understandable button't lethal stop you from being impartial.
kyippee
Ken
Thanks, I appreciate it. I'm not actually rejecting their statements, I'm learning by looking into the data with their tips and trying to trace down what could be causing it. I tend to look at multiple viewpoints, verify things, and weigh things together before deciding.
Same style at work. I don't think I'm arguing, instead I think my approach is testing and proving out things together. I can see how it can be perceived as arguing though.
FYI I did look into an alternative tuner and had a friend ask for a favor from their tuner who also works on other time trial cars. They might be able to get me a new tune for Friday + Saturday even though it's a holiday, and I think I will test the current tune on Friday first.
33 absolute, not relative. Subtract your ambient pressure. It's also in the recent log as Manifold Relative Pressure. Previous log you had Manifold Absolute and Boost Pre-throttle set to PSIG (Gauge pressure, which is the same as relative).
The tune won't change from 28psi to 17psi by itself. The normal airflow model strategy targets load/torque. Your load was 230+ in the previous log and 190 ish in the newer log. So totally different load targets, which is not how it works with the same tune on OEM airflow strategy.
I get you keep trying to make sense of things but the reality is, the tune is really bad. End of the day, it's your car, so do what you want with it.
kyippee
Ken
Thanks @razorlab! I am really confused by the boost numbers being different too. I swear to god I did not flash the car between these logs.
Something else must be going on (not a different tune). Really appreciate your help - I'm going to dig into this with more testing and like an earlier post, I have at least one alternative tune option in mind.
I'll stop posting here for now
