Trac on when speed cornering
SupraTimo
Marco
Bay Area
2020 Toyota Supra GR
Hi all, I have a question for everyone that might have had the same issue.
Lately my car has been turning on the trac on when turning hard on the freeway while on a turn, this has never happened before, I am lowered on swift springs and have Cusco front and rear sway bars.
It came to the point that I have to slow down just to make it not activate the trac control.
Anyone have an input on this?
Best regards
Rush_Supra
Rodney
Melbourne, Fl
2020 Supra ; 88 1jz Supra
Are you sure your TC is not actually on already and the light is just flashing when traction is lost (TC is working)? This seems most likely, because you have to actually press the button to turn TC off (and hold it to turn VSC off). I
suicidaleggroll
Colorado
Are you still on the stock tires or have you changed them? If you’ve changed them you have to set the tire size to “other” or whatever it’s called in the menu or the traction control will freak out while cornering.
SupraTimo
SupraTimo
Marco
Bay Area
Thanks all for the response.
I changed new tires, same size as stock, not even 500 miles on the new tires .
I got the alignment done at the same time.
NINaudio
George
Illinois
2023 Supra 3.0 Premium
What tires did you get?
visbits
Cincinnati
23 MKV MT, 95 Supra, 18 R8, 13 TTRS
Toe can heavily affect the wheel rotation speed which will make traction control more suspect to trigger.
Its likely an alignment issue if your tire dia match front/rear for whatever the stock ratio is.
SupraTimo
SupraTimo
Marco
Bay Area
I have new factory tires Pilot super sports.
I honestly don’t know what happened but it’s annoying.
Gonna probably take the car back to the alignment center to have them re check it.
Best
I'm assuming you checked the tire pressures? I've had tire shops in the past pump them up to 40psi+
