Using the OBDLink MK+ and Bimmercode
John8
AZ
I have purchased both, and have the BT working but can't find the place for the code for the vehicle or how to connect correctly even thought the BT says connected.
I have the Bimmercode installed on my phone and the app from the company for the OBDLink.
Any ideas?
kissmyrs
Gabe
SATX
A90 Supra
make sure its securely in odb port, car is on or diagnostic mode, bluetooth on phone active, and in your driver profile you can connect BT stuff....the app should pick it up after that
On Android,
open the Bimmercode app.
Click on 3 dots at top right
Click on Settings
Select the OBDlink option
Go back to main.
Click Connect.​
On iPhone
Open App
Click Gear icon at Bottom left
Under Adapter, chose the OBDlink
Go back,
Click done.
click Connect.​
John8
John8
AZ
On Android,
Click on Settings
Go back to main.
Click Connect.​
On iPhone
Open App
Go back,
Click done.
click Connect.​
I downloaded the current FW and got it to partly work but it won't show vehicle, so I have no way to choose BMW C4 or any vehicle.
John8
John8
AZ
I downloaded the current FW and got it to partly work but it won't show vehicle, so I have no way to choose BMW or any vehicle.
Finally got it to show vehicle etc., and in Expert mode went to dim and light and hit old, but there is no OK or way to code it. It likes it is the demo version but I paid for it and downloaded the paid version, strange.
after you change a setting, go back to previous menu, you should see "Code" up top.
John8
John8
AZ
I had downloaded and paid for Bimmerlink and thought I had paid for bimmercode but had paid for the other. That is why it would do Demo only. I asked Apple for a refund of Bimmerlink since I don't use it and it was an accident.
I did notice that my battery is at 64%, which isn't good. Should be near 100% with the little use the the battery has had with the Supra not running.
