Advertisement
Vibrations/Rattles in 2020 Premium Supra
Discussion in 'Issues, Warranty, Recalls, TSB' started by KeshyMKV, Sep 3, 2019.
  1. 084runnerltd
    084runnerltd Well-Known Member
    First Name:
    Jake
    Car(s):
    Feb 15, 2019
    ND
    437
    Liked:
    424
    Occupation:
    Financial Advisor
    Garage Profiles:
    Anyone have a rattle coming from the brace that runs behind the seats?
    I hear a rattle that I sounds like is coming from the brace, however I am unable to reproduce the sound by shaking it, the brace appears to be tightly in place.
    It sounds like a metal on metal sound...
    EastCoastSupra and KeshyMKV like this.
  2. Bulls23337
    Bulls23337 Member
    First Name:
    Car(s):
    2016 Mazda CX-9, 2008 Lexus IS F, 2004 Toyota MR2 Spyder
    Aug 19, 2019
    San Diego
    Liked:
    I'm getting the dashboard buzz around 4k - 5k rpm. Some rattles from the speakers/subs too.
    KeshyMKV likes this.
  3. CarGuy11
    CarGuy11 Well-Known Member
    Car(s):
    2020 Supra Prem/Assist DS Blue, 2016 C7 Corvette Z51, 2015 Jeep Cherokee Trailhawk
    Jul 10, 2019
    Pittsburgh
    345
    Liked:
    239
    I think the metal noise is coming from the seat belt.
    084runnerltd likes this.
  4. 084runnerltd
    First Name:
    Jake
    Car(s):
    Feb 15, 2019
    ND
    437
    Liked:
    424
    Occupation:
    Financial Advisor
    Garage Profiles:
    Ah could be, thanks I will check it out.
  5. OP
    KeshyMKV
    KeshyMKV Well-Known Member
    First Name:
    V
    Car(s):
    Jan 31, 2019
    MA
    172
    Liked:
    161
    Occupation:
    Supra Owner
    Garage Profiles:
    Yea, I think I am getting this too. It is on and off though.
    I still have the rattle in the door pin, and the area where the belt tine comes out...pretty frustrating.
    -V
  6. 084runnerltd
    First Name:
    Jake
    Car(s):
    Feb 15, 2019
    ND
    437
    Liked:
    424
    Occupation:
    Financial Advisor
    Garage Profiles:
    Well have some good news (for me anyway). My rattle, that I thought was coming from the brace, was actually coming from the middle snap points to the rear trunk cover.
    I had it all secured down, but must have unsnapped them when I swapped the BlackVue battery.
    :headbang: No more rattles, now just boomy bass. I will take crappy sounding bass over rattles anyday!
  7. OP
    KeshyMKV
    First Name:
    V
    Car(s):
    Jan 31, 2019
    MA
    172
    Liked:
    161
    Occupation:
    Supra Owner
    Garage Profiles:
    Glad your rattles are gone!!
    I quadruple checked those straps and everything is on tight. There still seems to be flex at the points where the cross bar meets the chassis behind the seats, I don't know if there is a fix for that.
    My dealer fixed basically 90% of the bass rattle when I dropped it off a couple weeks ago. They took the mat apart and added more insulation and it really did the trick! So sound system can be enjoyed more now.
    The door lock rattle is unbearable right now, I NEED that fixed, but I don't want to pull it apart myself and mess something up... :(
    -V
  8. kona61
    kona61 Well-Known Member
    First Name:
    Josh
    Car(s):
    5G 4Runner, MK7 Golf, AZW LE Supra
    Mar 25, 2018
    San Bernardino-ish, CA
    976
    Liked:
    1,322
    Garage Profiles:
    Amazon box wedge still going strong!
  9. 084runnerltd
    First Name:
    Jake
    Car(s):
    Feb 15, 2019
    ND
    437
    Liked:
    424
    Occupation:
    Financial Advisor
    Garage Profiles:
    #54 Oct 21, 2019
    You mentioned the straps, which is were I first looked, but everything was secured. Did you try the tabs that sit along the joint of the trunk’s cover? If not, press down and those should clip in.
    Besides the worst sounding bass since Cavilers in the late 80s, I have most of my rattles covered for now.
    For a short time there was a rattle when a seat was too far back hitting the cross member at times. Tricky part with that, is when nobody was in the seat it wouldn’t rattle and didn’t hit, I just needed to move the seat forward a hair to compensate for someone being in the chair.
    How difficult is it getting more foam around the subs? Are you just shoving it in? Or is it easy to dismantle?
  10. cutsman
    cutsman Well-Known Member
    Car(s):
    1972 Austin Mini (VTEC), 2020 Supra
    Aug 8, 2017
    75
    Liked:
    68
    Garage Profiles:
    As many mentioned, I noticed that there was a very audible vibration coming from the dashboard area when travelling on the freeway (and sometimes on the streets). It turns out the vibration was coming from the infotainment display on mine. If I held the bottom of the display, the vibrations went away. I went ahead and took a video of how much "play" there is on the display.
    To resolve, I used two (2) small pieces of 1/8" foam and wedged them between the display and the dash (on the bottom of display). No vibrations since installing.
  11. a90moe
    a90moe Well-Known Member
    First Name:
    Moe
    Car(s):
    MKV Supra
    Nov 10, 2019
    Kuwait
    694
    Liked:
    612
    Happens to me.. Normal I guess and only happens after spirited drives
  12. 084runnerltd
    First Name:
    Jake
    Car(s):
    Feb 15, 2019
    ND
    437
    Liked:
    424
    Occupation:
    Financial Advisor
    Garage Profiles:
    Wow, that is a lot of movement. I don’t won’t to touch mine as I don’t have that rattle and don’t want to create a new rattle. Lol
  13. OP
    KeshyMKV
    First Name:
    V
    Car(s):
    Jan 31, 2019
    MA
    172
    Liked:
    161
    Occupation:
    Supra Owner
    Garage Profiles:
    After upgrading to the Frequency Intelligent catback exhaust, this sound is almost completely gone. The design of the muffler area is so much better and cooling is more efficient it seems.
    Cheers,
    -V
  14. a90moe
    First Name:
    Moe
    Car(s):
    MKV Supra
    Nov 10, 2019
    Kuwait
    694
    Liked:
    612
    Glad it fixed it. I have an exhaust on the way too :p
  15. Meanie
    Meanie Well-Known Member
    Car(s):
    Oct 11, 2019
    Orange County, CA
    52
    Liked:
    34
    Wrapping the door pins once with electrical tape actually fixed my door rattles. Some BMW forum guys did this in place of removing the trim piece and adding felt, so I went with this as I'm not comfortable yet with prying the trim out.
    The other rattle I had on my passenger side ended up being a window key lock box that my dealer left wedged under my passenger seat. :rolleyes1:
    So far 90% of the rattles seems to be gone.
    Paolo and XtremeMaC like this.
Share This Page
Loading...
