Weird noise coming from back right wheel
Benjilis
Ben
St. Louis
Supra MKV, VW CC R-Line
It only started today on the way back from the gym.
when driving my car makes a sort of high pitched noise on the back right wheel. It sort of sounds like something is lightly grinding on my rotor.
I checked the rotor and brake pads and all is fine.
When I brake, the sound is louder and I can sometimes hear a “swoosh” noise as if liquid is moving around.
spta97
2021 Supra, 2020 BMW X3MC
I've read several posts of people getting a small pebble stuck between the disc and the backing plate. Any chance this could be it?
The swoosh noise I'm at a loss. Do you have a vid you can post with the sounds?
Benjilis
Benjilis
Ben
St. Louis
I’ll try to get a vid. Hard to do so as I drive though
Sereph102889
Wes
Guyton
I live on a pretty crappy crush-n-run street that has to be constantly filled with loose gravel bits every time it rains hard. Every single time this happens, the first time I drive the Supra on that road a pebble gets sucked through the brake ducting and into either the dust shield or the rotor area and makes a horrendous screeching sound until it eventually pops out. This is probably the cause of that issue, at least I seriously hope so for your sake. As for the swooshing sound, I have literally no idea unless you have a water leak somewhere and perhaps there's water in the trunk under the floor mat and you're hearing it slosh around under hard braking?
Benjilis
Benjilis
Ben
St. Louis
It did just rain Athena past few days and the streets in stl are shit. I can hear loose gravel a lot. Can I fix this without a jack?
spta97
Not on the supra, but I have had luck poking a long screw driver in to push the backing plate back and let the rock fall out.
Sereph102889
Wes
Guyton
How long did you drive around hearing the sound? Usually in my experience I have to drive no more than 5 to 10 minutes for the pebble to pop out, but I usually always make sure to accelerate pretty hard from a stop or from a decent 40 to 60 roll, this is usually when it pops out. As for trying to fix it yourself, if it is indeed just a pebble or gravel bit, you could try to poke your head under the car and look into the wheel hub/rotor/brake-dust shield area and see if you can spot anything. Probably won't be able to achieve much without jacking it up and taking the wheel off though. As for the potential water noise, I would 100% take the rear trunk mat out and check for water.
Benjilis
Benjilis
Ben
St. Louis
I was driving for 15 minutes.
I started the car back up and did a few hard stops and it resolved itself.
Thanks all! Would have never expected a pebble to be so loud.
Benjilis
Benjilis
Ben
St. Louis
It was a pebble that I drove out after some hard stops. I don’t hear the swoosh. It could have just been the gas tank
Qskid2
San Francisco, CA
2021 Supra 3.0, 2018 Street Triple RS
This was a big issue for a lot of the BMW M3's (F80 gen). Apparently, the best way to fix it for good is to just get in there for each wheel and push out the rotor backing plate/dust cover.
