Which is a better stud conversion kit? Mh or mevius
Maztaspawn
Buena Park, CA
2011 A90 Supra MKV
Hi, just wanted to get your guys input on stud conversion kits. I am thinking of getting motorsport hardware or wheelmate mevius. From my research mh studs rusts faster? For the wheelmate, theres not much info bout’ it. TIA.
rwense
Evan
Pittsburgh, PA
Agreed with @Rensuhlo get a thread cleaner and clean up the threads. They do tend to rust a bit depending on your brake pads. My DTC60s leave some pretty nasty brake dust, and when it gets wet it tends to rust fast. So keep that in mind. However they seem perfectly fine. I've had my wheels on and off probably 30+ times since I had them on and will be replacing the Studs over the winter since I've had a solid 6+ track events on them.
Keep in mind stud conversion kits are considered wear items and the frequency in which you need to replace them is a bit subject to how you drive/climate/how many times they see torque (i.e. how many times you take your wheels off and on).
