2023 Fusebox Different than Other Years?
lukas12p
Poland
Audi A4 B6 TDI, Supra 2023 MT
In my 2023 model after I set Sport Mode as default, exhaust is always open
Timmy_Jones
Timmy_Jones
Tim
NH
23’ 3.0 Base
Except upon startup and certain conditions. The actual fuse needs to be pulled, with the valve open to ensure it is always open.
lukas12p
Poland
When I start the engine (cold start) it stays open, I checked it after a few seconds. Does it close later?
Edit: I have manual version which is very silent to meet EU noise standards for manual (they are more restricted than for auto..)
ashari
Adithya
A90 Supra 3.0 Premium, C43 AMG, Range Rover Velar
Did you figure out which fuse to pull? I also don’t have the fuse puller on my 2023 3.0 Premium
Timmy_Jones
Timmy_Jones
Tim
NH
23’ 3.0 Base
Same as everyone else. Bought a pack of mini fuse pullers on Amazon! Came right out. Car lasted maybe 200-300ish miles and then threw a CEL for the exhaust flap error. Ended up going AWE exhaust anyways and just hooked everything back up to avoid codes.
GoldenEye
Golden
WA
2022 Supra
I pulled the fuse out with metal needle nose pliers while the car was running….worked just fine…
Timmy_Jones
Timmy_Jones
Tim
NH
23’ 3.0 Base
Can also do that! Just weird that mine threw a CEL! Like I said, went AWE and their little device that tricks the motor works perfectly.
ashari
Adithya
I took my fuse out and my burbles completely turned off which I thought was really weird
Timmy_Jones
Timmy_Jones
Tim
NH
23’ 3.0 Base
Mine didn't come with a fuse puller thing either....
They really dont like us 23' owners...double whammy if you get white ;)
Timmy_Jones
Timmy_Jones
Tim
NH
23’ 3.0 Base
Good to know if you clear the light its stored as a 'soft' code which doesnt show!
