Brake shudder?
That is funny as I actually had a beast sticker made as someone else called it the beast but I took it off when I made the new end plate so do not have a pic. Also I blew a turbo so do not recommend playing around with boost as the cars are fast enough . I have a charge pipe. Catless down pipe cold air intake and aftermarket exhaust. Nothing else no tune or boost. Run 30% ethonol mix. With just everything stock. Car Dyno at 426 max hp at rear wheels with 420 average using NASA classing sheet. Spend your money on tires , shocks , brakes , control arms and not trying to get more hp. You will be happier and your pocked book will like you too.
This ☝
funny bout the sticker and 100% agree!!
kaj
Fresno, CA
'00 360 / '69 Charger
It's probably been said, But your issue was likely uneven pad deposits from not bedding the brakes in properly. I've had this problem for the same reason once, I took some sandpaper to the discs and removed all the pad deposits. Problem solved. I made sure I bended them in right the next time ?
The odds of a rotor actually warping are pretty much zero
It's probably been said, But your issue was likely uneven pad deposits from not bedding the brakes in properly. I've had this problem for the same reason once, I took some sandpaper to the discs and removed all the pad deposits. Problem solved. Make sure I bended the men right the next time ?
I remember doing this with a drag car guy, buddy, long ago. Was thinking, wtf… But it worked! Great reminder/suggestion!!!!! Thx @kaj ?
Certainly doesn’t hurt to try
