Burger Tuning fail.
Titan Motorsports
Kyle
Orlando, FL
www.titanmotorsports.com
2020 MKV Premium White, 2020 MKV Premium Black, MK4 Supras. Among others.
The results the OP is seeing are not uncommon for high altitude cars on PiggyBacks or pre-programemd tunes. It is not unusual for these customers to require custom tuning. The same applies for older BMW's on JB4's.
OP is the first customer at high altitude to test the ProTune, after seeing these results we have our software engineer working at no charge on specific maps to better the results for OP and others in the future.
Supra dsb
Brian
Colorado
2020 DSB Supra Limited
Update:
Titan - Great response and have already created a new high altitude tune. Sending box back to have it reloaded.
Burger- not so great. They offered to refund my money. Said it’s not possible to produce less power than factory. Even though I’ve got 3 runs with and 3 without...
Supra dsb
Brian
Colorado
Thanks! Ashley is great and responded so quickly!
larrymz3
Arkansas
You're in Colorado, and with 91, no matter what you do, your car will always have less power, than the same car in a lower altitude,with better fuel. the good news is that all cars are affected by the higher altitude.
That jb4 intake is a joke, they claim that hot air won't affect the performance...
The mkv is an oven, by the turbo, intake area...
Agreed. I wasn't impressed at all with the intake and returned it. A true CAI needs to be routed outside of the engine compartment. I've not seen one yet, but, I'm sure a few companies are working on it.
Twisted Tuning
www.twistedtuning.com
yes we are among other things.
bobbybiglug
Brandon
Utah
'15 RCF, '20 Supra, '19 Tundra, '14 4Runner, '16 R1
Its great to hear that a high altitude specific tune is being worked on. I’ve held out on buying a tune until something like this was addressed. Any idea on how long until it’s available to purchase?
Titan Motorsports
Kyle
Orlando, FL
We are hoping to have a ProTune flashed and shipped today for OP. Again, high altitude cars are a whole different animal when it comes to tuning so we are hoping this resolves the customers current issues.
Custom tunes are always going to see high output their a piggyback, but we would still love to have a quick and easy solution for high altitude customers as well. Will keep you posted once we have results!
ST-AUTOSPORT
Tonni
Belgium
Supra MKV, Lexus IS300, Celica GT-4 ST205 WRC, MR2 SW20,
from your AFR curve, its running way too lean so it might be severely knocking, these cars target 14AFR in boost stock though, but with custom tune we rescaled the targets to 11.8/12 to aid in cooling, seeing great gains also.
Do propper logging or get a quality tune, those engines have a very specific torque strategy, a piggyback won't help...
Titan Motorsports
Kyle
Orlando, FL
Though that is a great strategy, his issue is target AFR & boost pressure at OP's altitude. The Piggyback on a standard map for a car at sea level was likely what led to the ECU causing the throttle to close when the ECU didn't see target. There are other cars making 600+WHP that were experiencing similar issues on flashes. Again, not uncommon for cars at high altitude and often times this is why a custom tune is best.
However, if a PiggyBack is mapped to cater to high altitude cars then there may be a solution for it after all.
Subzero05
Sounds like Titan will have it worked out . I love the unit on mine, albeit it’s stock with their tune and it’s been flawless . I personally never had much luck with burger but that’s just me , and I’m not a fan of a filter on a stick mentality, but again just me
