can’t reach HKS front camber bolts
Evolution
Sean
21 Supra
if you’re talking by mm then I would say 5mm is the correct size for HKS camber bolts. I wrote 3/16 so most of the people here in this forum using Amercian chart sizes, so I wrote it in American chart size to not get them confused. BTW, 5mm would work well for the HKS camber bolts and I tried it.
Ya but American sizes arent the same as metric. You cant use a 3/16" allen for a bolt designed for 5mm allen. The car and all its components are metric regard less if the car is here in America.
Rensuhlo
Chuck
Georgia
I used a 3/16 to adjust my 5mm.
Call the cops. Idgaf!
Mayday
Mayday
Nayef
Qatar
www.instagram.com
A91-MT
maybe you’re right, I think I got confused between hex head sizes and the ball end sizes. BTW, I will share what are the exact tools I have used to loosen HKS camber bolts so no one gets confused.
Mayday
Mayday
Nayef
Qatar
www.instagram.com
A91-MT
Yesterday I adjusted my camber bolts by using these tools and did the alignment at the shop.
I marked both of them in red color
I have both of these sets, and both of them worked great. I used the first photo screwdriver. BTW, You can loosen the bolts without jacking your car.
Evolution
Sean
21 Supra
5mm = 5mm. 3/16” = 4.78mm. Yes it will work. No it’s not right. Using a ball tip Allen wrench is only asking for a stripped bolt if using the 3/16”. Some top hat bolts are button head style bolts (normally a 4mm Allen) and those, especially stainless ones, strip like no other if you use the wrong size socket.
Rob_SER
Montreal
GR86, GR Corolla, K24 BRZ, C8 Z06
well it has been settled, for sure 5mm is the ideal size. Thanks guys, that avoided a headeach in a few months.
