Coolant Venting/Spraying out of main reservoir
Wonder if you can lemon law it if they’re not willing to fix it?
ethanmk5
ethanmk5
Ethan
2020 A90 Supra, Focus ST, E36
my advice is get a exhaust gas check on the gas in resevoir to ensure its not a gasket/block fail ... I have seen a very similar thing on an i8
Got this exact thing checked actually, came back fine no issues.
RAWSupra
Richard
UK
MKV Supra
good stuff ... then thats the worst scenario avoided ...
hmmm .. then sounds like an air lock somewhere IMHO ..
I would keep bleeding it ( via bleed screw .. which you should change for a brass one ) .. if pressure is lost in the system it will immediately boil over .. check all connectors locked and tight.
good luck bud
ethanmk5
ethanmk5
Ethan
good luck bud
Actually just put a titanium bleeder screw in about 3 days ago so far so good.
devnull
2021 supra 3.0 premium, 2021 Tesla M3P
Kind of confused how a wiring harness (assuming electrical) would cause coolant to spray in that location.
ethanmk5
ethanmk5
Ethan
The rodent chewed the wire connection to the coolant temperature sensor.
devnull
Damn, well that makes sense. Given the BMWness of the car, Im surprised that wasnt a fault code.
ethanmk5
ethanmk5
Ethan
Yep, thankfully the car is all good now and I've been able to enjoy it.
Dude…. There is a sensor for everything! I’m shocked as well.
