Funk's 23MT OEM+ Build
Funkjaw
Funkjaw
Michael
Austin
Your mom is my ride
I had a less than ideal experience with the dealership "straightening" my steering wheel; the service manager simply couldn't understand that alignment was fine, but driving straight, the steering wheel was off-center to the right.
Happy to read about your improved driving experience with the Suspension Secrets camber/caster plates. I ordered mine back on May 15th and they finally shipped today, along with the front offset caster bushings. I decided to get those instead of the non-adjustable ones "just in case" I bite the coilover bullet in the future and have to ditch the SS camber/caster plates.
Yeah you're going to love them. It's been over 300 miles and I am surprised just how good they feel. I really was worried about NVH and there is none at all. Smart move on the caster bushings as well. Going from 7.5 degrees to 8 degrees of caster gave my car a very pleasant increase in steering weight which I love - as well as just overall better response and turn in. đź’Ş
Mad0zodi
Gary
MO
'23 Supra 6MT
Right on. I'd also be happy if the combo gives even the slightest bit of steering feedback over stock. Now I need to order a set of Verkline or BBT rear toe links...
Funkjaw
Funkjaw
Michael
Austin
Your mom is my ride
Couple updates:
Installed:
  • Dinan DINANTRONICS X
    • Set it to Map 5 and it definitely feels like it picked up some power. Waiting for the weather to cool down to get clear apples-to-apples acceleration data, but the butt dyno says it's faster. Drives just like OEM too.. total win/win mod.
Removed:
  • Rapid designs rear diff brace
    • Removing the diff brace completely eliminated my between-gear clunk—huge win for the OEM+ build. I hoped switching from Twisted Tuning to Rapid Designs would help, but the RD brace clunks just as bad.
    • I'm also convinced a diff brace is useless for me. With the rest of my rear suspension setup (links, sway bar, diff ear lockdowns, subframe inserts), it only added unwanted NVH. Driving backroads at 8/10ths, there’s zero noticeable difference without it, so it’s staying off for good. Maybe it matters at 10/10ths on a track, but I doubt it.
Couple updates:
Installed:
Removed:
I'm not in the least bit suprised by this comment.
Supraluv
Ron
Cincinnati
2023 Supra premium , Z4 Coupe , 2002 MRoadster
Couple updates:
Installed:
Removed:
I also installed the Dinan DINANTRONICS X and it is as you say.Drives like totally stock but it definitely has more power if you give a little juice. The backend breaks loose much easier.
