Help reviewing BM3 OTS map logs
OldHead-MKV-Owner
Eddie
Maryland
22' Supra, 95' 300ZX SMZ, 22' F150 Limited
Need some help with my logs. A few things I noticed but unsure if they’re a problem. More importantly, am I missing anything.
The car runs great WOT as far as feel goes. At lower speeds between 2-3K rpm I has this weird hesitation/surging that happens.
My observations
  • Boost rarely hits Target, even in the tall gears. Usually between 1-2psi under Target. Wondering if I have a small boost leak.
  • If I’m doing a 2 gear pull, the timing is always worse on the second gear. Timing seems to be different for the same gear depending if it was the first or second gear in the pull. IATs shouldn’t be affecting this… in these cases below.
  • Timing pulls seem to be all over the cylinder range. I was expecting more pulls/corrections on cyl6 but that’s not the case.
  • Load actual is roughly half of Target. Not sure if this is an issue.
  • BM3 Flex Blend Factors (ign,fuel,trq) never hits 1 and I went as high as E56/57 (the reading shifted during the run). Even at E57 it was .95, E56 was .93
Any input would be greatly appreciated.
MODs (only engine performance listed)
  • AA DP
  • Eventuri intake
  • FTP charge pipe.
  • BM3 CustomRom
  • BM3 Flex-Fuel kit
  • xHP Stage 3 trans tune
Let’s get the shitty low speed driving log out of the way. I’m not smart enough to figure out the issue but it’s crystal clear from the log, there’s an issue.
09/18/23 MultiMap – Stage 2 Low speed Throttle Issues
https://www.bootmod3.net/log?id=6508c2b7ae729bad57686ee1
The rest are in order from oldest to newest. You will notice in the first log that I don’t have the Ethanol sensor on the CANBUS. I was reading from my fuel-it app.
09/03/23 Stage 2 E50 octane – 3rd to 4th E51
https://www.bootmod3.net/log?id=64fa8da8d10b43e4b40cbfc9
09/09/23 MultiMap – Stage 2 4th to 5th E53
https://www.bootmod3.net/log?id=64fc94ebc090c6dcb30c49bf
09/09/23 MultiMap – Stage 2 5th to 6th E53 Timing
Timing looks funky in 6th gear
https://www.bootmod3.net/log?id=64fc94e6ae729be4e81f1c51
09/10/23 MultiMap – Stage 2 4th to 5th E46
Timing looks good
https://www.bootmod3.net/log?id=64fdea48d10b43f4c48d54ac
https://www.bootmod3.net/log?id=64fdea46c090c6baea742403
09/13/23 MultiMap – Stage 2 3rd to 4th to 5th E46
https://www.bootmod3.net/log?id=65028574ae729b1524631e23
09/14/23 MultiMap – Stage 2 4th to 5th E46
Noticed towards the end of the log the Pedal is around 50% yet Throttle is at 100%.
https://www.bootmod3.net/log?id=65036fc7d10b435ca6e15a04
09/15/23 MultiMap – Stage 2 5th to 6th E52
Timing looks off in 6th gear. Cyl1 and 2. Hit 16.5deg in 5th gear
https://www.bootmod3.net/log?id=6504b45fc090c60e7ebfd822
09/16/23 MultiMap – Stage 2 4th to 5th E52
https://www.bootmod3.net/log?id=6505d40fc090c60e7ec08201
09/17/23 MultiMap – Stage 2 4th to 5th E56
https://www.bootmod3.net/log?id=65073b3ed10b430ffaa82528
09/17/23 MultiMap – Stage 2 3rd to 4th E43
In 5th cyl4 looks low on timing but the data says it’s correcting Cyl6. This confuses me, cause I’m dumb.
https://www.bootmod3.net/log?id=65073b3ed10b431366701fee
I know that’s a lot of logs but wanted to share a variety of gear pulls, IATs, E blends, etc.
Thanks!
OldHead-MKV-Owner
OldHead-MKV-Owner
Eddie
Maryland
I put the most recent log on datazap, because that bm3 log viewer is garbage. https://datazap.me/u/zrk/log-1695299959?log=0&data=1-4-9-14-24-38&solo=1-4-9-38
Looking at this log, I see absolutely nothing out of the ordinary. Aside from the low load drivability (which is normal, especially for over-the-counter generic maps), what problems are you having during these pulls?
Thanks for the reply Zach. Only issue I notice is low load drivability like you mentioned.
I haven't tuned a car since 03' and there are a shit ton more parameters to track, monitor, adjust. Just wanted to make sure I wasn't missing something before I get my DAW turbo and EOS mani installed.
You should be fine. I'd definitely splurge for a custom tune once you get those things.
ArmenLS1
Supra, Type R
You can send your logs to PTF, see if they can adjust anything and send you another map. They're tuners after all. ;)
They need feedback, I suspect that's how they adjust their maps moving forward.
ArmenLS1
Supra, Type R
I was looking at my Stage 2 93 octane 4th gear pull and comparing it to your e46 log. The amount of timing advance on your map, 16(aprx) Vs my 9 is insane, lol. Damn, E does wonders.
OldHead-MKV-Owner
OldHead-MKV-Owner
Eddie
Maryland
Definitely sending them my low speed logs. I need to get one on the stock tune but currently have too much E in the tank. I'll run that out this weekend and goes on straight 93. I'll log the 93 OTS map and the MultiMap to see if there are difference.
I already reached out to PTF, and they said they need that stock log to show those issue aren't present and help them figure out why I'm surging/hesitation.
I'll post logs here when finished and provide an update on working with PTF.
OldHead-MKV-Owner
OldHead-MKV-Owner
Eddie
Maryland
Before I learned the BM3 logging capabilities, I still had my JB4 in the car. On map 0, so I just used it for logs. On the Stage 2 93 OTS map my timing was hitting 14/15. 9 seems low to me.
I can post those logs if anyone wants. To be clear, I was running a BM3 tune but logging with the JB4 (set to map 0)
OldHead-MKV-Owner
OldHead-MKV-Owner
Eddie
Maryland
@zrk DataZap is Money!! thanks for the tip.
Also, what does the RAM prefix mean and should I be using those values. I noticed that's where you pulled engine speed from
Bryan / Briana
Your moms bedsheets
Higher speed logging items. Use those when possible. Some also don't have ceiling caps compared to non RAM logging items.
OldHead-MKV-Owner
OldHead-MKV-Owner
Eddie
Maryland
didn't see where I can adjust the sampling rates
Twisted Tuning
www.twistedtuning.com
Judging from the low speed logs the throttle issue you are feeling is the ecu modulating torque and boost. seems you're not pressing the pedal enough to populate a boost target (increase torque request) but boost in making 1-3psi based on mechanical load. its fairly normal. but if you feel it a ton then it can be smoothed out. Typically you dont feel this happening.
