Idle Vibration/Rev Issue
OBOB
OBOB
2020 Supra MKV, 2026 Supra MKV FE
Hi guys, I have been having an issue with my 2026 with 5100 miles, it has a slight RPM fluctuations and cabin vibration at idle, mostly when cold but occasionally warm. The car will make an different audible engine sound, rpms will jiggle and there will be a shake through the cabin. Car was bought brand new, followed break in procedure, only has a catback, and is running 5w30 bmw LL oil. The Toyota found no misfires, and BimmerLink shows no fault codes. Is this normal, or would you recommend checking anything? Car seems to have gotten this after installing catback or changing oil but I do not see how that could affect the powertrain so much. Thank you for your time and help!
tracer bullet
Greg
MN
2025 BMW Z4 M40 6spd
My Z4 does this as well, as did my 135i before it. I've gotten to think BMW engines just don't have a smooth idle.
My X3 is pretty good though, but it's an automatic (the others are / were stick), and I wonder if that makes a difference.
Curious if others have knowledge about it, but until then as a random data point, I've got similar fluctuations and always have.
exe36m3
Percy
NorCal
BMW
My old BMW 435i and Supra does this at times at idle. I assume it is the ECU adjusting fuel, air, timing.
You might feel this more as the new cat-back is lighter than stock, so vibration isn't as dampened.
