Installed intake and got a code. HELP!
itzTang
Socal
2024 Supra 3.0
Pushing the exhaust in more won’t do anything. Did you transfer gasket for the cat?
maserati
maserati
Alex
New Jersey
2025 GR Supra 6MT
I bought a new gasket. But it was kind of crumpling up when I was putting it in. You think I messed the gasket up? Seemed pretty ok
Much cleaner timing with the 91 stage 2 map.
Your fuel trims at cruise are pretty high. 12+ on LTFT. at WOT they are inline but it could be because whatever leak you have gets sealed with vac.
I didn't follow what full intake system you have?
maserati
maserati
Alex
New Jersey
2025 GR Supra 6MT
I have the MST V2 Intake. What do you think is leaking? The intake or the downpipe? Gonna go to a shop tomorrow
maserati
maserati
Alex
New Jersey
2025 GR Supra 6MT
Question. How tight should this v band on the downpipe be? I read online 18 pounds. So that’s what I did it to. Should I tighten it more?
You need to rotate the clamp part to below the wastegate arm pivot point. How you currently have it will block the full articulation of the wastegate arm.
Technically flipping the clamp around will make the above easier but you could probably get it done how you have it.
maserati
maserati
Alex
New Jersey
2025 GR Supra 6MT
thank you I had no idea. I rotated clamp downward and out of the way. Hand tightened it nice and snug.
maserati
maserati
Alex
New Jersey
2025 GR Supra 6MT
Do you feel exhaust gasses exiting around the vband?
i dont think so. and i mean in the cabin i smell some gas but thats to be expected going catless right? i just rotated the clamp and tightened it down. seems more closed maybe that might have been it
itzTang
Socal
2024 Supra 3.0
as long as it fit in the groove should be ok. unless it got misaligned.
