Losing oil, smoke only on idle
Guccington
Eddie
Lakewood, CA
2020 Toyota Supra, 2002 Toyota Tacoma Double Cab
Hello everyone, I’ve been dealing with this issue for about a month now. Just got my turbo replaced, oil pump replaced and also got a catless down pipe and armaspeed intake. I have a good amount of smoke coming out of the exhaust only at idle, I replaced the valve cover and turbo oil drain line. Going to take off the downpipe and see if there’s oil pooling in the exhaust side of the turbo but I’m at a loss right now as I’m getting no vacuum through the PCV hose when disconnected or any stumble with oil cap off. Any insight would be appreciated. The video was last night as I just let the car idle, and there’s a puff of smoke that comes out when turning back on after a short drive. Again only happens on idle and not while driving.
AZ Zupra
Dev
phoenix AZ
2020 GR Supra, 2009 GX470
Did you figure out what was causing this? My car does the same thing if I let it idle without driving for too long.
It is difficult to determine the smoke's true color from the video. However, it looks very white to my eyes, which is highly suggestive of coolant in the combustion process. I highly recommend you purchase a NOx tester to evaluate if any combustion gases are present in the coolant loop. If yes, you have a faulty head gasket. You can also compression test and leak down test the cylinders.
Do you have a catch can not disclosed in your OP?
Edit: yes, I realize this is a necropost, but might as well try to figure it out.
Edit 2: I know OP replaced parts, but I'm also suspicious of a PCV blockage and/or goofiness with the oil drain line.
concept
Dave
Southern CA
Fix/verify PCV system properly (don’t skip this)
Confirm crankcase vacuum is present
Only then worry about turbo/exhaust
It seems that the PCV is a fairly common failure point, and there should likely be slight vacuum at idle.
Another possible contribution is reduced backpressure from the elimination of the cat. Reduced backpressure (according to what I have read) can allow oil past the turbo seals, even if new.
Guccington
Eddie
Lakewood, CA
Thanks for everyones input on the matter, the head ended up being cracked in 2 cylinders ( 2 and 5). Got it replaced under warranty.
concept
Dave
Southern CA
Hopefully, that is not common......or is it? :oops:
2 port engine to start with. I'm not a big fan of integrated exhaust runners, makes the head casting overly complex and complex means more to go wrong in the casting process.
SJ-Ray
Germany
2022 GR Supra 3.0 | 2018 Suzuki Swift Sport
Not common at all..
There are thousands and thousands of 2 Port engines, mostly in the EU / Asian regions and i haven't heard of heads cracking left and right.
Just bad luck for OP, but great that he still had warranty.
Guccington
Eddie
Lakewood, CA
Not common at all..
Yeah a ton of bad luck, besides this I had to replace the turbo, downpipe, oil pump and alternator. All within 4 months.
