Need help picking a color!
Elektro
United States
17 i3 94ah, 22 Supra 2.0
I had ordered a red but the dealer found a black one nearby with exactly the same specs and options but without a four month wait so I went black.
I like it. But I'll probably get a car wash pass next winter lol.
My prius prime and miata were both silver and I refused to buy another silver car! So boring! Would not have 3 in a row!
BrettS
Alberta, Canada
2016 Scion IM/2020 supra
I assume OP is talking colors alone. Not special edition colors..
Downshift blue was not a special edition color, it was just offered as a 2020 color then they discontinued it. The special edition blue color is refraction blue
Reactions: zrk
Mason
Mason
Kenosha WI
then I stand corrected, which is crazy since I'm an all knowing deity
Reactions: zrk
I'll chime in with different option.
Go with whatever then wrap it. Not too many color options for Supra.
romanLegion9574
Imo white seems to be the most common Supra color.
I typically always select white cars but prefer a bright white without a pearl cast to it… Hence the reason I went with tungsten silver.
I've seen far more red Supras than white in the PNW.
romanLegion9574
Given I have an Absolute Zero white Supra, I'm biased, but I'd go with white. I entirely understand not going for red or yellow since they draw a lot more attention.
The white has a pearlescent finish which looks amazing when it catches sunlight just right.
timmygogdon
Connor
Washington
2021 Supra
I’m biased since I own a turbulence grey, but IMO turbulence grey and Absolute Zero look the best.
In the end, it doesn’t matter what we think. You’re going to be the one driving it.
Have you ever seen an absolute zero in person? Can you see the outline better on the absolute zero than the turbulence?
timmygogdon
Connor
Washington
2021 Supra
Phantom Grey, White, Blue, Yellow and Turbulence Grey they are all hard to fine.
I’ve seen more turbulence greys here in seattle than white. why is white so hard to find do you think?
suicidaleggroll
Colorado
It was between the Renaissance Red and Turbulence Gray when I was looking. Then I saw the Renaissance Red in person and it just looked bland and uninspired, so I went with the gray. If the Supra red looked anything like the deep metallic red that Mazda uses I would have jumped on it in a heartbeat, but it's just boring. Turbulence Gray looks fantastic and I'm happy with my choice.
timmygogdon
Connor
Washington
2021 Supra
Weird because whites the only color I haven’t seen haha i’ve seen way more reds and yellows/greys and never seen a white
timmygogdon
Connor
Washington
2021 Supra
Thanks for your input! What about in darker lighting or at night? Does the white still look good even when it’s rainy out too? I’ve seen the turbulence gray in dark weather and it looked amazing so how does the absolute zero hold up?
timmygogdon
Connor
Washington
2021 Supra
isn’t the tungsten silver more of a whiteish color than silver? that’s another one i haven’t seen in person
Mason
Mason
Kenosha WI
same here! I see so many reds/yellows/black/gray but i haven’t seen a single white or tungsten silver haha
i went to a local supra even with over 15 supras. i had the only Turb grey there. it still does blow me away being able to see the light-to-dark curves one the car. its not static color at all, unlike red/yellow imo
