Oil extraction - is it possible
Not to curse myself, but I always never grab the actual arm of the socket wrench when tightening oil bolts in aluminum pans. I only tighten from the center.
Last Lemming
Last Lemming
Greg
LA
2020 Supra MKV, 86 944 Turbo
Same here. But that’s when it happened!
Last Lemming
Last Lemming
Greg
LA
Felt like it started to, yes.
Last Lemming
Last Lemming
Greg
LA
Yeah, I’ll be able to remove it. I stopped tightening right when I felt it go “soft” as I rotated.
visbits
Cincinnati
23 MKV MT, 95 Supra, 18 R8, 13 TTRS
Could also just have been debris on the crush washer.. i'd just take the bolt out and bite the bullet and see what you're looking at... I cant imagine dropping the oil pan is that big a pain on this car... my M3 oil pan was pretty easy when I did my S55 crank hub.
Eddy90
Ed
Toledo
2023 Supra MT
Was the subframe in the way?
visbits
Cincinnati
yeah 100%.... I cant think of a car that doesn't have a subframe directly under the oil pan. On the M3 I just took the subframe and motor mounts loose and supported the engine with a support beam on the strut towers and let the sub frame sag down.. drops 4-5" and provides adequate room to get the pan off.
