Parking Assistance Malfunction [side protection]
Sereph102889
Wes
Guyton
Did you ever find a fix? Got coilovers installed and got a bunch of chasis and parking assistance codes. They went away but I'm still stuck with the side protection warning. My side sensors aren't picking anything up
This may not help you but I will give it a shot. Not that long ago I was having all kinds of crazy electrical errors on my car. It started with simple stuff like the "Parking Assistance Malfunction" error and other stuff and ended up progressing into a freaking nightmare. I THOUGHT I had checked everything that made since but I was wrong and it ended up being that the bolt for the battery lead in the engine bay was incredibly loose. Tightening that down solved every issue I was having. Don't ask me why I didn't check that first, but I didn't lol.
Eastwood
Well I currently have it disconnected. Was hoping removing the battery terminal and powering down would reset it.
but I’ll try that and checking if the sensor plugs are tight.
it’s weird all of the sensors work and pick up everything except the sides.
CafeRacerQueen
Daniela
Washington DC
‘20 M4 CS, ‘24 GR Supra 45th LE
Brand new 2024 here, just started having this issue two days ago. It’s under 40 outside so I haven’t been able to do anything about it yet
VeeBeeA90
Vivek
South Africa
880whp 2020 Supra, 820whp Evo 9, Astra VXR
Also having the same problem, sensors are working but the error keeps popping up.
Tried everything, battery, clearing faults. Nothing seems to work.
Been told that Toyota need to update firmware,
But I'm tuned with reflex etc and can't have them flash and lock the ecu.
Any suggestions ?
kaj
Fresno, CA
'00 360 / '69 Charger
.... And people ask me why I bought the base model.
Eastwood
I downloaded Toyota ISTA and Techstream.
calibrated all of my sensors and everything cleared.
SupraCess
MA
23 GR Surpa and a turbocharged FRS
I had the same issue after I disconnected the battery in order to remove the DME.
After firing up the car again, same error code came up.
I did the same as you, cleared the codes and disconnected the battery again for 30 min, but this didn't solve the problem.
The solution was surprisingly easy. Drove the car around the block and the error code cleared itself after a minute of driving.
I'm going to try driving my car around. I received the message after disconnecting the battery.
