Parking brake actuator replacement on Supra/another BMW?
romanLegion9574
I was looking to replace my rear pads and noticed that the actuator housing was chipped from having made contact with the rear control arm from back when I was lowered. The parking brake warning had come on with code 480818. I believe that swapping the actuator should do the trick -- anything I should know when doing this? Does this need to get coded to the control unit or anything?
Z4m40i
Salt Lake City
2020 BMW z4 m40i, 2020 BMW X7 40i
The e brake motors are just held with some hex bolts. Nothing fancy about it, and no coding required. The e brake motors are specific to g20 with m sport/supra/z4 calipers. Other G chassis BMWs have rear brakes manufactured by TRW and are not compatible with the Mando manufactured calipers on the Supra.
I have e brake motors from when I upgraded the rears if you’re interested.
