Power gains from a meth kit?
tyler.bn
Tyler
2021 3.0 GR Supra Premium
What kind of power gains can I expect to get from a meth kit? I'm currently looking at the titan motorsports one.
stock turbo, cracked 2021 dme and catless
(plus a charge pipe with inlets)
2021Supra
Alabama
2021 Supra, 2021 Lexus RC300, 2007 Tundra, 1975 Ch
For fueling or cooling only? I am using mine for cooling only and it seems to do the job into the intake manifold. I chose the AEM meth kit. Start at 9psi and full spray at 15psi. I chose the middle injector which is 250 I believe. I have had zero issues. Only complaint is anytime you power up the car, open the door or trunk, etc, the pump turns on and stays on for several minutes.
Tsuki8
21 3.0 AZ BM3 E50 WMI
What mixture are you using?
mkvB58KING
2020 GR Supra 3.0 Premium
If you don't have access to ethanol, meth is amazing. I was running 100% M1 on a Pure800 gen1 B58 and it got me up to 29psi with plenty of overhead. In a perfect world, I'd rather run E85 but that's a challenge here in Canada.
cinosa
'22 Nitro Yellow Supra 3.0 Premium
I'd be too afraid to run 100% meth for fear of being rear ended and having the tank explode and cover me in invisible flames. You're a braver man that I.
tyler.bn
tyler.bn
Tyler
I have access to ethanol but can only run e50 without port injection, would you recommend spending the extra buck on port injection?
I was looking at methanol as a cooling solution
2021Supra
Alabama
I am using BoostJuice for now. Purchased off of Amazon for around $50 for four one gallon containers shipped to the door.
KBGT
WA
2020 supra
Water/meth for cooling and port injection for fuel delivery.
FYI you can buy 5 gal of methanol on amazon for about $110 shipped, buy distilled water locally and mix 50/50 in your old boost juice gallon containers. Works great and saves money. Also if you have a local chemical supplier methanol is like $65 for 5 gal pail.
Tsuki8
Very nice, what tune are you using?
I understand the BoostJuice is for cooling only.
2021Supra
Alabama
Tuned with Marin. Switched from Visconti just recently. E70 blend, E50 blend and 93 blend. Bunch of modifications also.
