Removing airbag
MSport
Jon
Kingsport
23 Supra
Just got mine back you want to go a little further back than where you’d think
calmeda1
Christian
FL
2021 Toyota Supra 3.0 Premium
I got the airbag out of the wheel but I cannot get this clip undone to full disconnect it. Anybody have any advice??
I had the same issue. I was able to remove it eventually in a way, but if you're going to do that, I would do it with caution.
There's a part in the clip where it should simply be press and pull, but clearly that's not the case. I used some vice grips to press that area and pulled lightly. If the vice wasn't tight enough, I would add 1/8 of a turn and try again until it would come out. Don't over tighten or you'll crush the clip.
Maybe there's a better way to do it, but at least this method worked for me with my available toolset.
tvnguyen
Detroit
You need to depress the pin with either a screwdriver or pick tool and pull the connectors apart
john99teg
johnreb
bay area, california
a91 nocturnal special edition
So when we disconnect battery for airbag, do we lose settings including my bimmercode settings?
STV3
Steve
Bimmercode settings stay. I think you may lose your number button presets and a few other things though, but nothing that you have coded gets lost.
J29DB03
Maybe and no. You’re “supposed” to lose any presets you have programmed to the 8 buttons, the stereo equalizer, etc., however I didn’t lose anything the past two times. My battery tender may have something to do with that, no idea. But no, you will not lose BimmerCode settings.
john99teg
johnreb
Lol your battery tender is acting like a second battery source. Definitely keeping your modules awake and alive. Be careful with srs and live voltage!
J29DB03
Oh shit! Can’t believe I didn’t think of something that obvious. Damn. Last time I do that.
