Reverse light into 4th Brake light?
[email protected]
PEPE
Posts
162
Tampa
2020 Supra A90, 2001 S2000, 2009 STI
Dunno if Im confused but both EU/US lights have 3 male pins, my guess is that EU harness plug has 3 females to engage while we have 2 which (I confirmed) physically
Advertisement
consultadrone
Posts
187
Southern California
Dunno if Im confused but both EU/US lights have 3 male plugs, my guess is that EU harness plug has 3 females to engage while we have 2 which (I confirmed) physically
Yes, 3 pins. In the EU part, 2 are for 12V and one is for ground. In the EU part, one 12V pin is for the reverse lights, and the other is for the fog lights. @Evoh posted the pinout for that above. I suspect that the 12V pin for the fog portion does nothing on the US part (hence no corresponding female connector in the harness plug). They just use the same connector module in both because it's cheaper than making different plug connectors.
Again, best way to know for sure is to apply 12V power to the pins on the US part and see what lights up.
Evoh
Posts
Bay Area, CA
2021 Toyota Supra 3.0 Premium
I plan to try that tomorrow but I also suspect the fog light pin on the US part will do nothing. I doubt is has both red and white LED's.
The hardest part will be figuring out how to wire up the tail light 12V to the fog light pin of the EU part especially if the existing harness does not have a wire for that pin.
consultadrone
Posts
187
Southern California
Definitely keep us posted!! Yeah, it's going to require some wire splicing to get that 12V fog pin connected to the brake output.
[email protected]
PEPE
Posts
162
Tampa
Would it be as easy as to tap into the 12v power wire going to one of the rear brakelights while installing another female plug on the plug itself?
If so best route would be to cut the plug and have someone install that female in there etc? And then reconnect everything? I know all of those plugs require special tools in order to be serviced without damaging them though and I dont have those tools :(
Evoh
Posts
Bay Area, CA
The install in complete!
I also tried applying 12V to the rear fog pin on the original light and nothing lights up as expected.
This is what the plug looks like. As you can see there are no metal contacts where the rear fog light pin goes in. It was also plugged up on the other side with a rubber piece that I reused later. What I did was solder a wire(green/yellow) to the rear fog light pin and drill out a hole in the connector so the wire can go though. This way, it can still be plugged in normally. Hopefully the pictures can show what I mean. I made a hole through the rubber piece so the wire can go through and put the rubber piece back in so prevent moisture from getting in.
I tapped the green/yellow wire to both the tail light and the third brake light wire. You can't tap it into the regular brake lights since that also acts as your signal light. You could tap it to only the third brake light but I wanted it to also be on when the headlights are on. I also needed to install a diode so the tail light does not also light up the third brake light since they are all connected now.
The third brake light wire is the black/red wire. It goes under the head liner which is where I tapped into it.
The tail light is the grey/yellow wire. I tapped into it in the bundle of wires near the fuse box. This is also where I will install the diode.
There is also a rubber grommet in the rear of the trunk there you can route the wire through by just poking a hole in it. It leads the the back of the rear fog light.
Hope this helps!
[email protected]
PEPE
Posts
162
Tampa
Hope this helps!
OMG Broo thanksssssss , one small favor, please give me more clarity on this "The third brake light wire is the black/red wire. It goes under the head liner which is where I tapped into it. I dont have it clear were I can get to this cable and Im not good enough in electrical to shoot for the same install you did, although is what I would prefer but I will settle with it working with the brake light.
CalvinL
Calvin
Posts
Singapore
Supra Mk5
Oh WOW! that is lovely.
Now for the request for the flashing capability initially when braking like the F1 cars. Possible?
Evoh
Posts
Bay Area, CA
Sorry, the picture isn't very clear. This guide does a good job of how to get under the headliner: https://www.supramkv.com/threads/blackvue-dr900s-2ch-install-diy.4921/
METAL
K2
Posts
93
Peoria, AZ
2021 Tungsten GR Supra
There is a module called Kahtec that will make any circuit flash but you just have to find where it can be applied.
METAL
K2
Posts
93
Peoria, AZ
Now we just need to see a video of this mod in action.
[email protected]
PEPE
Posts
162
Tampa
Is there any access to the 3rd brake (red/black)cable next to the fuse box, so we dont have to reroute a cable from the top?I know in some cars the cables change colors along the way. It doesnt hurt to ask right! ;)
Evoh
Posts
Bay Area, CA
It looked like that cable was leading to the front of the car so I assume it goes to the fuse box under the passenger seat.
sphinx000
Posts
Toronto, Canada
2014 Lexus IS 350 F-sport rwd
Hope this helps!
Question!
Why do you need to tap into the both tail light and 3rd brake light? Is the red LEDs capable to light up brighter when brakes are applied? I thought the red fog leds only light up and that's it, it doesn't go brighter when u brake does it? If it doesn't go brighter than tapping it to the taillights only is enough no? Could use some more clarifications :) but thnx for this info!
Evoh
Posts
Bay Area, CA
Question!
The tail/brake lights(the triangular shaped LED) also function as the turn signals. If I tap into either the left or right brake light, the rear fog light would also blink when I signal left or right. I think there is a module somewhere controlling this light.
I tapped into the line shaped LED that only functions as a tail light. The way I have it, the red LEDs would function as a brake light during the day. But when the headlight are on, they are just the rear fog lights. Applying the brakes when it is already on does not make it brighter.
I you only want it to function as a rear fog light OR a brake light then you only need the tap into one of the lines. Hope this helps.
Advertisement
Advertisement
