Stage 2 OTS Builder - 91/93 Octane, Flexfuel, 6MT and AT
QTR FMS
Fahad
Qatar
2024 6MT
Hi everyone,
I made this Stage 2 OTS Builder software to replace the previous Stage 2 6MT 91 + M30 OTS post, as I wanted to cover more ROMs and make it easier to install.
This software generates a Stage 2 BIN for 21 B58 O1 roms between 00005D553 and 00005D554 families.
How to Use:
Load a stock multimap MHD BIN file, Select the settings that match your vehicle: fuel type, downpipe, and transmission. Configure the optional FlexFuel settings as needed, select the output location, and then generate the file.
Recommended MHD Flasher Settings
  • Disable cold start (for Catless DP)
  • Aftermarket downpipe
  • Cooling: Track or Sport mode
  • Intercooler: Sport mode
  • Remove top speed limiter
  • Set exhaust flap to 2 using the BC button
Download
Github Link
Feel free to post your datalogs, any issues you experience, or any revision suggestions.
QTR FMS
Fahad
Qatar
2024 6MT
How does this benefit those of us using the MHD OTS software?
I'm kinda dumb.
Its my own custom tune that i have made to fix some of the issues that most people faced and been complaining about with MHD OTS tune such as overboost and torque limiters, and i have optimized few things for more power and flexfuel with ethanol content upto 50%.
Also im using MHD+ functions that is not in the MHD OTS tune.
I have tested it on few cars overall it should be closer to a custom tune than MHD OTS maps, atleast it would be 80% of a custom tune, and its not encrypted so you can fine tune it as needed in case you want to make minor changes that suits your car and driving style, such as throttle mapping or base wgdc or fuel scaler.
it also a good base map for those who want to start learning to tune or take it further with bigger turbo etc.
and im planning to add more features in the future based on the people feedback and support on testing and development, such as stage 2+ OTS for pure800 turbo, b58 m0/m1 and s58 support etc.
@QTR FMS
I see you are changing "BMWinjafs_fac_RatAirMax_T" to a higher load. I personally would not do that. It's the load ceiling for STFT influencing LTFT. It's not a limiter.
QTR FMS
Fahad
Qatar
2024 6MT
@QTR FMS
hi bryan , yes i changed that, my idea was that with the way the neural network works for fueling and ltft will help to make the tune more consistent across different cars for ots tune.
on my car i havent had any issues with ltft taking control, do you prefer to have only stft to influence wot for ots tunes where fuel scaler is not optimized to the car?
You can get some really wacky LTFT in non full load that way.
QTR FMS
Fahad
Qatar
2024 6MT
I will review the logs and maybe change that in the next version, but overall what do you think about the tune, do you think this is a good alternative to mhd ots maps? Is there any more feedback you have on the tune?
I've never looked at MHD OTS values as they are locked.
QTR FMS
Fahad
Qatar
2024 6MT
No, please don't. I'm on good terms with MHD. Their work is their work.
I agree with you on protecting MHD IP. Just to make it clear, nothing was used from MHD OTS in this builder; I only used the MHD OTS to learn what tables they have changed and why, which is basically the same as if I had taken a datalog using their OTS.
And from what I have seen, they haven't changed much, and they haven't even used their own custom MHD+ functions, which is a shame, as they could have used their own boost control strategy instead of the OEM, which would have solved the overboost issues people have been complaining about.
And also, I shared a couple of screenshots of the software with MHD before releasing it so they were aware about the tool and didn't have any issues with it.
