Check engine light and weird error codes after flashing MHD Stage 2 (93) OTS Map
mikeag96
mikeag96
Houston, TX
2021 Supra 3.0 Premium
Interesting I don’t have any flex fuel kits installed yet I just got my ecu back from fetmo and the first flash did the codes and has been doing it ever sense. Any ideas?
Check your ECU connections. You could have some loose connections. I would go ahead and reseat all connections starting from back to front. Also, are you using the latest app version of MHD?
TimsSupra
tim
supra mk5 2022 3.0 premium
Will do this and report back. And yes I believe so let me double check.
Hasan
Hasan
United Arab Emirates
Too many to list
I had the same error codes and just cleared them with the MHD app and everything seems to be fine.
On the other hand the throttle seems to be overly sensitive at times. Does anyone have similar expensive.
Rensuhlo
Chuck
Georgia
You can request a more linear throttle when you go custom tune.
TimsSupra
tim
Same codes after the battery disconnect and ecu disconnect and reconnect. Any ideas?
Habu
Josh
Earth ?
Just got my ECU back from FEMTO and went through all the steps carefully to flash an MHD Stage 2 OTS map (93 Oct.) I'm getting a check engine light along with these codes.. anything to be concerned about?
MODs:
AA catted DP
AWE track exhaust
Visconti flex fuel kit
I got this same code 30E08 after flashing MHD OTS Stage 2 too. Expect the car won’t start now. I’ve flashed back to stock then back to OTS and still nothing. Even disconnected and reconnected the battery. I’m about to burn this damn car down.
mikeag96
mikeag96
Houston, TX
Shit. That's sucks man. Have you checked your battery? The charge might be too low. You also might want to check your ECU connections and make sure they're all properly seated. I would pull all the ECU connections and reconnect, from back to front, just to be sure.
BMWAF
In orbit
A90 Supra; FN2 CTR
Did you solve this? I get the same code but my car starts and drives fine. The code seems to throw a CEL. Any more information? This is driving me nuts.
bushido
Miami
yes
honestly? electrical tape over the CEL :headbang:
Timmy_Jones
Tim
NH
23’ 3.0 Base
I also got a bunch of codes and a CEL for battery something (on a trickle charger) once I drive the car and turn it off / on again they all go away. I think this is oddly normal to see, but mine clear out.
BMWAF
In orbit
A90 Supra; FN2 CTR
I get this one, that causes a CEL and doesn't seem to go away:
30E08 - Power management: Battery below upper startability limit.
Surely my battery isn't going bad after only 18 months.
Habu
Josh
Earth ?
Yeah i got MHD+ to work with car now after sending the dme back to Femto. I don't believe I have that code anymore although id have to double check. I do have check engine light on most of the time due to my downpipe. If the car starts and drives fine just clear it and see if it comes back. If it comes back and starts still that would be kinda weird. Can check the battery voltage with a meter directly on the battery. I don't know if these cars can detect the cca load drawn during startup. If your battery is only 18 months old I'm sure its fine though unless you leave the accessories etc running with the engine off.
Timmy_Jones
Tim
NH
23’ 3.0 Base
I am about to reflash, pending I pass state inspection here. Ugh. I will keep an eye on the codes when I go back to a new flash on the charger and let you know!
Erty
Eddie
Los Angeles, CA
'24 Supra 3.0 Premium MT
Happens to me too. I just clear codes and it goes away...
BMWAF
In orbit
A90 Supra; FN2 CTR
Mine seem to return randomly (after 100-200kms of driving) and doesn't appear to go away until I manually clear the code.
Your DP shouldn't trigger the CEL as you can tell MHD to code it out. I'm not 100% sure yet but I think my CELs are not DP related (I've set MHD to get my car to ignore them) and think this battery issue is actually causing my CEL. I also think the weird post flash iDrive gremlins I'm experiencing are due to this battery code too. Frustrating af.
I wonder what we have in common because this doesn't seem to be a common issue. I'm a February built, 2023 MT. Snap?
