ColonelAdama
ColonelAdama
Greenville, SC
Hey guys I had a question on the IAT spoofing feature, my normal IAT is at 90-105F, is it safe to use the feature to raise timing a little bit? If so how much can I spoof if I’m running an E30 blend? I’ve spoofed it before but only running e25-e30. I just want to be sure it’s safe to spoof lower than the actual IAT. I do have some timing corrections on maybe 1 or 2 cylinders at times but they keep climbing after the correction. And do no timing corrections mean I’m safe?
If you already have corrections, I would not spoof.
jmikes
Jake
Tampa Bay, Florida
2021 3.0 Premium Silver
I wouldn't really mess with IAT spoofing tbh. I'm worst-case scenario (Florida heat and humidity and a 23.5 PSI Jesse map) and the only times my IAT's get high enough to pull timing or cause throttle closures is on long pulls to over 100 MPH; and you'll virtually never go past 90-95 on public roads unless you're an idiot or want to be a racer boy.
Also, IAT spoofing did very little for me. Does a lot for some, nothing for others. I leave it off.
nicecatsupra
Springfield, IL, United States
2025 Supra MK5 6MT
Hello, I am new to the JB4 platform and am only running Map 1 on my 6MT 2025 Supra 3.0. Decided to log after I had my AA catted dp installed, no other mods at the moment. It feels sluggish coming out of 1st gear at times so I logged it. I turned down FF to 20 in the settings but the log still shows 50? Can someone check my log and advise?
https://datazap.me/u/nicecatsupra/l...hannels=1x4-34&sizes=50x50&sc=1-4&axes=shared
jmikes
Jake
Tampa Bay, Florida
Do we have anyone that can review jb4 logs? I dont see any recent reviews.
ColonelAdama will probably still review them, most people have moved on to unlock and MHD/BM3 since it's so cheap and widely available now.
FitmentIndustries
Wisconsin
n/a
Been a busy 5 months learning nearly everything there is to know about JB4 on the B58 platform. Funny how trying to get my catless MT running right turned into countless log reviews and custom tuning on the JB4tech.com forum. As Jesse said it best, it's all about experience.
Without further adieu, here is everything I know about tuning with this piggyback:
SECTION 1: Getting Started
  • Install guide:
    https://www.jb4tuned.com/instructions/JB4_BMW_B48_B58_INSTALL_CARB.pdf
  • A used unit may not have an EWG connection. I highly recommend having this. Especially if you have an aftermarket downpipe, or want to run ethanol, or want to use absolute boost control. Just get the dang thing if its missing.
  • If you have a new unit, congrats. You already have one. Install is easy when you remember the stock intake comes out in one piece. And remember to have a pick tool for the connectors to lift them off gently.
  • Strongly consider getting the bluetooth connection if you intend to do any custom mapping. The JB4 Mobile app is something like $30, but it is worth it. Highly recommended for easy logging.
  • If you have purchased a used unit, the first thing you will want to do is go back to default settings. There is no reset button. You will need to go to the JB4 forum (https://www.jb4tech.com/forum/model.../4984-jb4-b48-b58-firmware-settings-and-notes) to see the default settings and set them manually.
  • Check that the JB4 Firmware version shown in your app is the latest stable version of P158. If not, updating takes 5 min. Keep the car on, engine off, phone battery charged (enough). Maybe turn off other bluetooth devices if you have a lot connected.
SECTION 2: Selecting a map
  • JB4 works by modifying the MAP and TMAP sensor readings to tell the car’s DME that more (or less) boost is needed. The EWG works the same, but for wastegate position.
  • The JB4 has two modes of boost control, which is how it achieves power gains.
    • Additive - the boost targets are an offset on top of stock boost requests.
    • Absolute - the boost targets are fixed and override stock boost requests.
  • When you connect with the app, you will see the JB4 has 8 maps:
    • Map0: Stock tuning, fully disable JB4
    • Map1: Additive map with peak of 3psi over stock added (91-93 octane)
    • Map2: Additive map with peak of 4psi over stock added (~93 octane)
    • Map3: Additive map with peak of 6psi over stock added (not recommended for Supra)
    • Map4: Absolute target map with peak of 23psi target (E30) FP upgrade required.
    • Map5: Absolute target map with peak of 26psi target (E30+ fuel) FP upgrade required.
    • Map6: Custom tuning map allowing both additive (below 10psi) and absolute (above 10psi) targeting. Setting RPM1500 boost below 5.7psi will make entire map6 additive, setting above 5.7psi will make entire map6 absolute target.
    • Map7: WMI map (boost varies based on WMI additive, meth flow, and other criteria)
    • Map8: VALET / Low Boost Map
  • The JB4 ships with Map1 enabled. Remember to set it back to Map1 if you bought a used unit.
  • Map1 is the mildest map the JB4 comes with. BMS recommends all JB4 noobs to start by taking a Map1 data log. All fuel is different, your 93 might suck and Map2 won’t work well.
  • In safe conditions, shift to 3rd gear, go full throttle from 2500 RPM to redline while your app is connected to the JB4. It will automatically log the run, and store it under the logs tab. You can then email it to yourself, or just save as a draft (as i do).
  • I prefer to turn log grouping off. Depends on who is reviewing your logs.
  • The datalog file name will read as your JB4 engine code(P158), the map you were in, how many runs, and the date.
  • Sign up for datazap.me . This website appears to have been made for reading JB4 log csv files (amongst other tuning platforms). They host the logs so we can just link them here. I don’t think csv can be uploaded. JB4 PC app can be used too - see Section 3.
  • Here’s where you can make a decision: Do you actually want to DIY tune or just have someone more experienced do it?
    • non-DIY:
      • Post your log (datazap link) in this thread or JB4tech. Myself or others will review as we can.
    • DIY:
      • Keep reading ;)
  • Provided that your Map1 ignition advance and fueling look good- Map 2 can be logged on 93 octane or higher. I do not recommend Map 3 for high boost B58 models like the Supra. Its more intended for Gen1 or non TU engines.
  • Access to ethanol will open up options for those on 91 octane to use maps higher than Map 1, and those with 93 octane to try Map 4/5 or improve their existing maps.
  • Remember, always log at lower settings/Maps before moving up. If you aren’t sure if the log is any good, post it for review.
  • Set a boost safety (boost failsafe) of ~2-3psi above your maximum boost. For most people, 23 is a good set point. If you are running high boost, something like 25-26 works. this failsafe protects your turbo and engine in-case you goof something up with wastegate tuning, for example.
SECTION 3: Datalogging
  • So you’ve got a datalog, or a hundred (if you don’t group logs) lol
  • You can either use the official JB4 app or datazap to read the csv. Or excel, google sheets, or JMP if you’re weird like that (yes I’ve seen it lol)
  • I, personally, am not familiar with the JB4 PC application, but the instructions can be found here: https://www.jb4tech.com/forum/model...eview-ab/138-jb4-laptop-connection-directions
  • I like using datazap because it lets me configure multiple views easily. This means I can look at different groupings of engine parameters during the run to make it easier to interpret. I will get into which groups I use after talking about the parameters:
  • Parameters:
    • Boost: This is the pressure, in PSI, in the charge pipe just before the throttle valve. Under ideal conditions the boost value will be within 1psi of the boost set point value (see Target). Though this may not necessarily apply to all models (MTs). More on that later.
    • Target: The JB4's target boost. The value is determined by the JB4s internal mapping and many other parameters including engine speed, pedal input, intake temperature, gear, map-specific boost targets, and other internal logic.
    • Boost2: Post throttle manifold pressure. This is the boost in psi that your cylinders will receive. The DME will use the throttle to keep manifold pressure under target if the charge pipe pressure (boost) goes above target.
    • ECU_PSI: The ECU (Engine Control Unit) is just another name for the DME (Digital Motor Electronics) or engine computer. The ECU_PSI is the DME observed boost which is being transmitted by the JB4. When boost is close to target then ECU_PSI will be close to DME_BT (see DME_BT). The JB4 will alter this value above and below DME_BT as needed to manipulate the throttle blade.
    • DME_BT: The DME_BT displays the current DME boost set point. This is determined by the DME and flash map and will typically stay between 10-16psi on a stock 2021+ Supra. But can vary even more, due to DME logic. This value generally does not effect the JB4's boost target unless it drops suddenly to indicate a fuel ceiling(see Trims), traction control, overboost, etc.
    • IAT: Intake Air Temperature is measured in the manifold just after the intercooler. It is measured by the TMAP sensor (Temperature Manifold Air Pressure) combination sensor. Both boost and temperature in one physical sensor. High IAT will cause the DME to pull timing, robbing power from the car. This is known as heat soak.
    • Pedal: Gas pedal input. This is the position of the pedal under your right foot with a range of 0-100%. While using cruise control this value will always report zero. Must be at 100 for the entirety of the run for proper log evaluation.
    • Throttle: Throttle blade position (0-100%). At full load, the DME will modulate the throttle to keep manifold pressure(see Boost2) under target when Boost exceeds (or almost exceeds) Target. If throttle dips below ~80 mid pull, that indicates some overboosting, and its likely that wastegate tuning is needed.
    • WGDC: Wastegate duty cycle is most easily explained as “wastegate position offset”. It is essentially the JB4 applying a bias on the wastegate position solenoid to open or close the wastegate as needed to control boost. This is inactive if you don’t have the EWG connection. This parameter is formulated something like this:
      • PID Output = boost_error (boost vs. boost target) * Internal Mapping * PID Gain (see wastegate tuning)
      • WGDC = FF + PID Output
        PID is turned off for additive maps on firmware V28 or newer. WGDC=FF.
    • FF: Short for "feed forward" or the fixed component of the PID boost control system. This is the starting point for boost control and the PID will then adjust WGDC above or below this value as needed for fine tuning. The user adjustment variable FF / wastegate adaptation value (0 -100) scales the FF value and will adjust itself over time as part of the normal JB4 learning routines. In addition, this value can be user adjusted by RPM using the duty bias settings(see wastegate tuning). The default value of FF is 50, but you may see it change across logs. If you don’t want it to adapt, enable Bit 1 under options. Duty bias ("FF by RPM") settings do not adapt.
    • Ign1-6: Ignition Advance is the number of crank degrees BTDC (Before Top Dead Center) when the spark is turned on to ignite the fuel/air mixture in the cylinder. In JB4 world, we want to see all 6 cylinders climb linearly to redline. Any step down in that climb is a timing correction. A drop greater than 3 degrees usually indicates insufficient octane, but not always. Ign advance is very important. 1 deg of timing is arguably more power than 1 psi of boost (actual tuners correct me). So keep this in mind when you start cranking up boost levels. It’ll also be healthier for your engine to not pull timing.
      credit: @i3igpete
    • Trims: Fuel trims (0-50). The Trims display shows what the STFT (Short Term Fuel Trim) signal is doing. This value is displayed as 25 = 0% trims, 50 = +33% trims, and 0 = -33% trims. This is the difference between how much fuel the DME expected(from stock map fuel lookup tables), vs how much it actually needs to keep AFR(see AFR) on target. Since JB4 can’t control fuel, it relies on the DME to make these corrections. So usually trims will be higher than 25. I typically advise people to keep their maps under 40 trims, but if you log frequently, you may be able to push it a little more while keeping an eye on AFR. You can sometimes lower your boost targets in RPM ranges with high trims to mitigate this. The biggest factor for high trims is E content and the delta between ECU_PSI and Boost. If Trims are pegged at 49 for multiple data points, you are leaning out. Less E or less boost.
    • AFR: Air/Fuel ratio. B58 typically targets Lambda=1 (14.7:1) for most situations, but at high RPMs, or poor octane, or high cylinder/exhaust temps, it may start to get into the 13s. You will usually see this in low to mid 14s. No need to be alarmed. B58s run lean due to direct injection. You may see a spike on throttle let-off or gear change (see Autoboost Redux). If it is not sustaining 15+ for more than a couple data points, its not much to worry about. If your trims stay pinned at the top, you have an issue.
    • Meth: More to come on that - Still learning.
  • Recommended Parameter Groupings -
    • Config 1: Boost control
      • RPM
      • ECU_PSI
      • Boost
      • Target
      • WGDC
      • DME_BT
      • FF
      • Throttle for diagnosis
    • Config 2: Fuel and Timing
      • RPM
      • Trims
      • AFR
      • IGN1-6
      • FP_L and FP_H if AFR and Trims are high
  • Config 1 allows you to verify the car is near its boost targets and that WGDC is following FF closely. Meaning the PID output and boost error is small. If WGDC is not staying near FF, wastegate tuning is likely needed. Almost always necessary with catless DPs, and some high flow. You will also likely see a lot of throttle activity. More on that later.
    • With V28 or newer firmware, PID is off for additive maps (ie. WGDC=FF). Use the recommended methods in the wastegate tuning section.
  • Config 2 allows you to verify the car has enough fuel headroom, and that the octane is sufficient for the boost targets. Read about Trims, AFR, and Ign1-6 above.
  • If something seems unusual, I check that Pedal is at 100. Then I check to make sure there wasn't a traction loss event that can cause boost and timing drops. I just look at the RPM curve - if it has any sudden steps, it was probably wheelspin or clutch/trans slip.
SECTION 4: Ethanol Blending
  • It is important to remember that ethanol has less energy density than gasoline, therefore your fuel system will be compensating for the higher volume of fuel. However, it is high octane (usually 105) and has excellent cylinder cooling capabilities. This allows the engine to run cleaner and more aggressive ignition timing (big power gains!) Since JB4's extra boost is already pushing the stock fuel map above normal, it is important to keep watch of trims when blending. I have seen many logs where people have overdone it and leaned out (usually a CEL, possibly limp mode, or trigger JB4 AFR safety)
  • Per your Supra's owner's manual - up to E25 is permitted on the stock map, so generally that is my max recommendation to begin with.
  • You can achieve this by following roughly a 1:3 ratio of E85:gas when you fill up. Typically this is about 3 gallons of E85 into an empty tank, and the rest with gas.
  • I tend to start with just 2 gallons, as usually that is enough to start cleaning up ignition timing, without risking hitting the fuel ceiling. Higher E mixes may actually reduce boost targets, as B58 has an internal fuel flow limit.
  • After filling, drive a bit(10-15 min) to let it mix.
  • Log and watch trims. Generally want to stay under ~45. If you are seeing trims 40+ with your blend, I advise logging more often to check on it and AFR.
  • An ethanol analyzer like Fuel It can help if you want to run higher blends of E and higher boost. It can integrate with JB4, and will show ethanol content in your gauges and logs. It cannot "auto-tune/flex-tune" your maps, however.
  • If your tune is turned to 11/10 (ie 22+ psi) and requires high octane and minimum E content, an E analyzer is strongly recommended.
  • If you are running moderate boost map like 2 or 4, you may still benefit from a little ethanol even if you are on 93 octane. All depends on timing corrections. E analyzer probably not needed since they won't be as octane sensitive.
  • HIGHLY recommend the fuel pressure control upgrade for JB4 if blending. This increases your limit of E25 up to E40. (Keep FOL between 60-70) Think 30-40hp gains. https://burgertuning.com/collection...ts/s58-and-b58_gen2_fuel_pressure_upgrade_kit
SECTION 5: Wastegate tuning (FF / Duty Bias)
  • Usually needed for any car with non-OEM downpipe to compensate for the freer flow.
    • Used to prevent overboosting at low-end and midrange.
    • Used to reduce throttle intervention for boost control.
  • Here is a valuable resource that I learned from that can help until I write this section:
    https://www.jb4tech.com/forum/model...g-review-ab/4229-jb4-duty-bias-ff-tuning-info
  • N54, but still 90% applicable.
  • FF value is saved PER MAP, but duty bias is global.
  • You can seriously screw up your tune here if you don't fully understand it - be warned.
  • High flow catted DPs or Catless DPs WILL need duty bias adjustments. Here is a good starting point:
    • duty_15duty_20duty_25duty_30duty_35duty_40duty_45duty_50duty_55duty_60duty_65duty_70
      323232323536394855576262
      Not every car is the same. Probably will require more fine tuning, but these have worked for several cars without many adjustments needed.
    • For AT cars setting FF: (think ~50 oem dp, ~40 hi flow, ~30 catless)
    • Adjust duty bias as needed so that ecu_psi is roughly 1 psi below dme_bt to achieve max power without throttle closures.
  • I do tuning for MT Supras, reach out if you need any help.
    • P158 V28 (or newer) firmware will be needed, and FF is typically set much lower on MTs. (think ~25-30 oem dp, ~15-20 hi flow, ~10-15 catless)
    • Duty bias tune as needed. You want ecu_psi to stay within 12-16 psi for the entire pull. Do not try the AT method of "ecu_psi 1 psi below dme_bt"
    • Stick with additive maps.
    • Keep boost targets lower below 5k rpm. Taper is key. (ie. most MT cars won't take over +5psi below 5000 rpm)
    • dme_bt will be much higher than ecu_psi. this is normal. On MTs, you need to "underboost".
      Reduce duty bias until calc_tq stays below 48 to prevent triggering "injection monitoring", where the car will pull boost if it thinks its using more fuel than it should. This car needs a reduction in duty5000.
      Too low can cause an underboost limp mode, harmless, but you probably reduced FF or duty by too much. you want as high as possible while keeping calc_tq under 48
I will likely write more about options settings, Map 6 configurations, and some general diagnosis of common issues I have seen. I may elaborate a little more on the techniques I use to begin custom tuning a car at a later point.
Hope this helps you get started with JB4.
Since others have asked: Tips/donations not required but very much appreciated for guide support and log reviews! Venmo - @ColonelAdama
Awesome!
Eastwood
Don’t let this distract you from the fact that Hector is going to be running 3 Honda Civics with Spoon engines, and on top of that, he just went into Harry’s and bought three t66 turbos with nos, and a motec system exhaust.
jmikes
Jake
Tampa Bay, Florida
hey I was racing the other night watching my tune on my laptop and the screen began flashing and saying "WARNING: DANGER TO MANIFOLD!!", do you know what i need to do to stop that???? can JB4 help?? pls helpings...!!!
tcshmark.808
Hawaii
2025 Supra
Seeking for your help Coloneladama lol,
I have the MHD BEF e85 flashed on (provided by Terry), it’s def a lot quicker for sure, but I would like to dial in a map 6, I was pretty dialed into make adjustments with the jb4 when the car was locked, but now that the torque limiter is removed and throttle closures don’t happen often, how di I go about making changes? im thinking just watching the wgdc and ign timing, and boost curve are the values i need to look at? Enlighten me please lol
I’ve attached a map 6 log. Basically similar settings to before I unlocked and flashed the car. But because there’s no torque limiter can I make the boost ramp more aggressive essentially??
https://datazap.me/u/mark-gorospe-j...hannels=1x4-34&sizes=50x50&sc=1-4&axes=shared
