Transmission Lag
mvtte
Matthew
GA
'22 Supra 3.0 Prem
Started noticing yesterday that when I shift from P to D there is a delay for like few sec once I take my foot off the brake pedal for the car to move forward.. has anyone else experienced this?? Car has bit over 10k miles and only mod is catback exhaust
humblemoto
Boston Massachusetts
'21 A91, '07 E60 M5, '19 Panigale V4S
May be related so searching “throttle hesitation” on the forum, potential known issue. I believe resolved by ecu update.
mvtte
mvtte
Matthew
GA
'22 Supra 3.0 Prem
That doesn't sound like throttle hesitation, just sounds like a cold torque converter.
definitely didn’t feel like it was throttle hesitation.. i noticed this happens when i do a cold start. So the cold torque converter won’t be an issue??
antonio88x
Antonio
Jupiter, FL
Does it happen if you let the car sit for a minute after starting it? Before shifting out of park?
mvtte
mvtte
Matthew
GA
'22 Supra 3.0 Prem
So I noticed it happens on cold starts.. so of course I wait for the car to warm up and idle for a minute or so
antonio88x
Antonio
Jupiter, FL
So even after the cold start and you put it in park, it has the delay? I'd keep an eye on it. Maybe it'll just go away.
I'm guessing it shifts fine in auto and manual mode, in sport and comfort?
mvtte
mvtte
Matthew
GA
'22 Supra 3.0 Prem
It shifts fine when I’m on the road. It’s only when I’m shifting from P to D where I have that lag before the car moves forward.
SupraYYJ
Victoria, BC, Canada
2021 Toyota GR Supra 3.0
I know little about ZF8s, but this was how the Honda M6HA in my '97 Prelude telegraphed that it was about to destroy itself. :(
You have a '22 and your powertrain warranty is still in effect, so I think you should report the problem to your dealer.
All my cars have hill assist. So in my driveway, for example, I switch from P to D, there is “hesitation“ so I don’t roll back. Could this be what you’re referring to?
antonio88x
Antonio
Jupiter, FL
I believe cars with hill assist use the brakes to hold the car.
CarolinaSupra
James
Carolinas
A90/370Z
I have a 2020 with over 55k miles and it's done this since the beginning.
For clarity, simply shifting from P to D and releasing the brake, without pressing the gas, the car will pause before eventually creeping forward.
If you shift from P to D and immediately press the gas, there isn't a delay, at least not for me.
It probably goes unnoticed by most people unless you're really paying attention to it.
