Whining sound behind passenger seat
elam
Elliott
San Francisco, CA
2020 GR Supra
There is a mechanical whining noise that comes from the subwoofer area behind the passenger seat. The whining seems to correlate with the throttle as evident in the video. It only happens either on the second start up of the car or after it’s been driven a while on first start up. The sound stops as soon as the ignition is switched off.
I noticed the sound starting after I flashed stage 1 BM3 on the car. Other mods include intake and exhaust. Could it be the fuel pump?
Did you ever try to see if turning off ASD helps?
Sounds like the fuel pump. I recently had this happen after a tune and believe it's because some people are setting some tables incorrectly.
Mine only happens when waking the car up. Listen to this and tell me if it's the same sound.
elam
Elliott
San Francisco, CA
2020 GR Supra
It’s definitely similar, though I’m not sure it’s as audible, especially from the outside. Is your fuel pump upgraded?
Yes stock LPFP. I flashed back to my own map today and it no longer does it.
Anos
Anos
Mkv Supra
Any update on the noise? I have the exact same problem
BMWAF
In orbit
A90 Supra; FN2 CTR
I have this too. After flashing MHD Stage 2 it sounds like I have an aircon port in the trunk. Is that normal?
Erty
Eddie
Los Angeles, CA
'24 Supra 3.0 Premium MT
Mine does this but only for about 2 seconds after unlocking the car, I thought it was normal.
a90.galiza
Ian
Oslo Norway
A90 Supra
Hey, i also hear that sound even after cold start. While idling the car, is it a faulty lpfp?
