That's what I do. Super easy with this tool: https://a.co/d/1VqpWmJSounds like the answer is to remove the wipers yourself before getting the windshield replaced.
Yup, and mark them and the stud with a paint maker before removal.Sounds like the answer is to remove the wipers yourself before getting the windshield replaced.
Yep, paint marker crossed my mind too.Yup, and mark them and the stud with a paint maker before removal.
Itās been a minute but rereading my post I believe you want to expose the 16mm nut and loosen it (but donāt remove it). Then press down on the wiper blade between the blade portion and the arm portion, where they come together and are held together with a spring. Push and ābendā the wiper blade there and it should move freely (and independent of the other wiper). Move it to where you want it and the release the pressure and tighten the 16mm nut and replace the capI just had my windshield replaced on my 2022 3.0 and I'm having the exact same issue you were having. My wiper looks just like your photo. So, instead of driving back to safelite this seem like an easy fix. I haven't gone out to check things out yet, but from what I'm reading, I have to look where the wiper arm attaches to the post of the wiper motor, there will be a cap that I pull off (I'll see a 16mm nut) that I don't have to remove and then I'll also see a button that I depress to freely move the wiper arm to it's proper location? Do I have that right?
I guess I'm an idiot and will have to take a ride back to safelite. I can't figure it out.It has been
