2020 3.0 Supra Knocking Noise
Msh21
Rum
DMV
2020 3.0 Supra
Just came back from the gas station and noticed the car making a knocking/ticking noise
Seems like it is coming from near the gas tank but can't really tell
Been only filling up premium gas from Shell. Car is completely unmodified. I got the car with 7k miles on it after Toyota had to change the fuel pump
Any ideas on what it could be?
Gonna need some more information. There's nothing really to.. knock there.
You mean when driving?
Msh21
Rum
DMV
2020 3.0 Supra
It's when the car isn't in motion. So just standing at a light or even when parked. Can't really record it since it's so faint but literally sounds like a knocking beat coming from near the gas tank.
Killswitch24
Nathan
Graham NC
All the time? or very rarely?
I haven't experienced it in the Supra, but sometimes the evap system can make thumping noises when it's checking tank integrity.
Msh21
Rum
DMV
2020 3.0 Supra
Where is the evap system located?
It literally just started today. Gas station is like 5 minutes from my place so after filling up, every time I stopped at a light and when I parked the car, I kept hearing it (before turning off the car)
I was thinking maybe I overfilled on gas. I don't know if that's a thing. But I was going to drive it around a bit tomorrow to see if the noise continues.
baagel
2021 Supra 3.0 Premium
Shouldn't have overfilled unless you continued to top off after the pump clicked.
Since you mentioned Toyota replaced the fuel pump, it might be worthwhile to bring it in to them and have them listen to it.
Msh21
Rum
DMV
2020 3.0 Supra
I actually did continue to top off.
If the noise is still there tomorrow or returns are any point then I'll definitely be taking the car in right away!
darkknight302
Dang
West Allis, WI
2021 Supra 3.0 Premiun
You should not ever top off. You will create more problems for yourself.
https://www.automoblog.net/topping-off-learn-why-you-should-never-top-off-your-gas-tank/
https://www.consumerreports.org/car-maintenance/should-you-top-off-your-cars-gas-tank-a1176503026/
Motorknut
i noticed a noise that’s almost like a helicopter sound, happened twice - both after filling up the gas tank. Noise disappeared at the next start up. I have not filled the tank to the top since then, and the noise hasn't come back.
I suspect it’s Related to the tank ventilation valve, been meaning to release the gas filler cap next time it occurs to test the theory. Thinking that the gas station attendant may have overfilled on those occasions
Noise from fuel tank
3TMagnetMan
New Jersey
2021 Supra 3.0 premium
Sounds like a hot exhaust as metal expands and cools. Makes ticks and knocking sounds. I could be wrong.
R_R8TED
Dan
South Carolina
www.pixelatedgamer.com
2021 Supra MKV 3.0, 2020 Jeep Wrangler Unlimited
You just overfilled, I heard that once and under the exact same scenario, immediately after leaving the gas station. I was mixing for E30 and wanted to get a little more 93 in there to get the mixture perfect and over did it. As others have stated, just don't top off anymore in the future :thumbsup:
mvtte
Matthew
GA
'22 Supra 3.0 Prem
your car runs fine? no CEL?
